Please help! Valve cover bolt snapped.
Old Mar 16, 2020
Andrey Zhdanyuk's Avatar
Andrey Zhdanyuk is an unknown quantity at this point
Long story short I Snapped the bolt after changing the gasket I need some sort of rubber cork until I can take it all apart again and get the bolt out. I can’t seem to find the right cork anywhere I look. Any advice will be appreciated
Old Mar 16, 2020
Wankenstein's Avatar
Re: Please help! Valve cover bolt snapped.
Try Ace Hardware for rubber stopper. Use a reverse
​​​​​drill bit to remove the broken bolt. Find another bolt in local junkyard, local Honda dealer or online.
Happened to me a few years ago on a 6th gen. Use the correct torque spec and crossing pattern when installing valve cover.
Old Mar 17, 2020
mac25's Avatar
Dr Krieger of Modification
Could also try covering the hole with tape, then covering the tape/valve cover metal, with liquid gasket.
Fez
Sep 18, 2017 06:44 AM
x3nzox
Apr 28, 2013 09:31 PM
JuiceboxEH2
Apr 13, 2013 07:20 PM
XI JuNiOr IX
Jan 13, 2012 02:39 PM
clawhammer
Nov 8, 2010 09:19 AM
