Replacing the valve cover grommets
Old Nov 6, 2010
clawhammer's Avatar
clawhammer is an unknown quantity at this point
How do you replace the valve cover grommets? Specifically, how do you get the new grommet on to the bolt? I've already ruined a set of those rubber grommets trying to force it onto the bolt, looking for help.
Old Nov 7, 2010
MelJ's Avatar
Trance Addict
Re: Replacing the valve cover grommets
Are there 2 sets for the Civic(one on top and one underneath the VC)? I know on my Corolla, there were just 4 grommets that came off when you took the 4 bolts off. Installation was pretty straightforward. You'd put the VC on over the 4 gigantic screws, place the grommets on next, and then the bolts. Just didn't wanna overtorque them.
Old Nov 8, 2010
clawhammer's Avatar
I ended up taking the bolts and the grommets and soaked them in used motor oil for an hour. Then I put a socket on the ground, put the grommet on top of it, then the bolt. I hammered the bolt through the grommet and the oil loosened it up enough so it wouldn't break.
LionSpratt
Jan 29, 2017 11:07 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
