2005 lx oil pan gasket 4 loose washers position
Hi
2005 civic lx replacing oil pan gasket and 4 washers came loose and now I have no clue in which nuts or studs it goes on. From what I see the 2 studs on the center of each side don't have a washer on but the problem is I have 4 of them and im stuck not knowing how to install this cause I don't want to have oil leaks again and this is the second time replacing this. Im worried if the first time I did a mistake. This time I bought a torque wrench to get it done properly and bought a higher quality gasket. Please any ideas on this? Thank a bunch
NEVER MIND JUST FOUND THOSE CAME INSIDE THE GASKET ITSELF IN THE CORNERS
beaterlx
Apr 27, 2018 06:59 PM
john1976
Oct 11, 2015 06:08 PM
JJ291
Sep 11, 2013 11:34 PM
