Engine Mounts
Old Jan 14, 2020
tight's Avatar
tight is an unknown quantity at this point
Engine Mounts
Replaced all my engine mounts with aftermarket. Big mistake. Vehicle vibrates like crazy now. After reading into it, the general consensus is to only use OEM here. I want to replace them with OEM mounts but they're expensive to do all at once. Is there one or a couple of the engine mounts that help with vibration more than the others?
Thanks!
Old Jan 15, 2020
BrotatoChip's Avatar
Super Moderator
Re: Engine Mounts
If you're looking for OEM you could try getting some good looking ones from a junkyard to save some money.
When you say aftermarket are you talking about cheap OEM replacement mounts or stiffer, performance mounts? I have used cheap OEM replacement mounts on multiple cars with no issues.
Old Jan 15, 2020
tight's Avatar
Re: Engine Mounts
They're cheap OEM replacements. Pretty hard to install them wrong and the vibration definitely started after I put them on. Not sure what else it could be.
Old Jan 15, 2020
Super Moderator
Re: Engine Mounts
I've only ever replace one or two at a time. Very possible the mounts you have are just stiffer than OEM and replacing all at once made it noticeable.
omegabeams
Jun 4, 2019 04:23 AM
E Sully
May 1, 2016 11:57 AM
Jan 28, 2016 04:54 PM
bsmiley
Apr 2, 2015 08:34 PM
nieuport17
Jan 3, 2012 07:27 AM
