P1361
Old Jul 8, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
P1361
I change the crankshaft sensor yesterday but I have the code comes up, TDC p1361. The timing might out a little bit, it shut off pm me today.and turning over but wont start until the engine cool down a little bit.
Old Jul 8, 2019
Re: P1361
two different sensors.
CKP sensor (CranKshaft Position) is down by the crank pulley and protrudes out the aft bottom portion of the lower timing cover at about the 4-5 o'clock position (when looking directly at the crank pulley)
TDC sensor is on the head, penetrating the upper timing cover.
Old Jul 8, 2019
Re: P1361
Yes, you are right. I realized that I made a mistake last night with the crankshaft sensor. It should be the camshaft instead..
Chad1971
Oct 19, 2025 10:23 PM
IROKGEN7
38
Feb 18, 2016 07:27 PM
Afay33
Sep 2, 2011 12:02 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
EG06KRS
Oct 9, 2007 01:55 PM
