04 Civic 1.7 p0339
Old Sep 25, 2019
Chad1971's Avatar
Chad1971 is an unknown quantity at this point
04 Civic 1.7 p0339
Hi all new here cuz I'm goin nuts! Lol to begin, I got car with 3500 RPM rev limit, read codes p0339, put new oem crank sensor, and pigtail just to be safe and new can sensor both oem, it started and revved up to 7000 no prob, then died! Now it will crank a long long time then all the sudden start up like nuthin wrong but cel and rev limit at 3500? Pull crank sensor plug and itl start after few seconds of cranking? Have triple checked timing? Reset codes, Instantly get cel again? I read online bout s shorter timing belt? Or should I be leaning towards pcm ? Please anyone! Lol thank u I am a mechanic shop just don't have really expensive Honda tools! I do have the 12 volt ground and 5 volt all at sensor.
Old Sep 26, 2019
BrotatoChip's Avatar
Super Moderator
Re: 04 Civic 1.7 p0339
Intermittent failures are never fun. Sounds like you've got everything you need at the sensor itself. It may be worth while pulling the crankshaft pulley and lower timing belt cover off and having a look. We once saw broken off teeth on the exciter ring. Other things to check for would be debris around the exciter ring, dirty terminals on the sensor and in the connector, fluid in the sensor/connector, etc.
https://www.civicforums.com/forums/3...asket-job.html
Old Sep 26, 2019
Chad1971's Avatar
Thanks for the ideas, I did check the exciter ring and it was good nothing wrong, I put new pigtail on the wire harness,I'm looking at pcm I guess?
Old Sep 26, 2019
Super Moderator
Yes, you really want to make sure you've narrowed it down to that first though. Replacing the PCM also requires a dealer to reprogram keys, unless you also replace the matching ignition switch and immobilizer ring with it.
Old Sep 26, 2019
Chad1971's Avatar
Ya I know, I can't do anything else at this point? Iv dun and tried everything? I found a good used pcm with imobilizer for a good deal so I guess I'm gonna try that?
Old Jul 3, 2021
Koch99's Avatar
Koch99 is an unknown quantity at this point
Did you ever get it fixed mine has the same problem and I've replaced everything but the ecu
Old Jul 3, 2021
Chad1971's Avatar
I never did! Dam thing the guy decided to just sell it cheap and get something else. Drove me nuts and still does when i think about it. Hope u grt it fixed.
Old Jul 3, 2021
Koch99's Avatar
my buddy has the same civic the was rear ended so I'm just going to put his in there and see if that changes anything and if it does I will let you guys know
Old Oct 19, 2025
Pirate13's Avatar
New Member
Pirate13 is an unknown quantity at this point
Let me know if it works. I'm having the same issue.
Old Oct 19, 2025
Pirate13's Avatar
New Member
Is there any way to test the current computer before replacing it?
IROKGEN7
38
Feb 18, 2016 07:27 PM
themadness
26
Oct 23, 2012 05:21 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
kwildly
Apr 16, 2009 02:00 PM
CivicPro01
Sep 12, 2008 10:06 PM
