What is this?
Old Mar 6, 2020
DonJulio's Avatar
DonJulio is an unknown quantity at this point
What is this?
What is that part circled? Purchased a wire harness that is supposed to be 01-05 manual but it is missing that plug.
Old Mar 6, 2020
Slumpertcivic's Avatar
Re: What is this?
That’s for your EGR system.
Not common in 01-02 cars, but pretty common in 03-05.
Your ECU will quickly notice if that is not working as expected.
Old Mar 6, 2020
DonJulio's Avatar
Re: What is this?
So it cant be deleted?
Old Mar 7, 2020
Re: What is this?
we can't answer if you don't tell which year car you have....
Old Mar 7, 2020
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Re: What is this?
You can try deleting, but I always found that ctrl alt del works best. Good luck.
Old Mar 7, 2020
mac25's Avatar
Dr Krieger of Modification
Re: What is this?
You can remove it and buy a blocking plate, but the CEL will always be on. Not really a problem unless you need to pass an inspection.
Old Mar 7, 2020
DonJulio's Avatar
Re: What is this?
It doesnt need to. Can I leave it unplugged until I get a block plate or a thermostat housing without an egr?
Old Mar 7, 2020
Colin42's Avatar
Re: What is this?
Yep.
Old Mar 7, 2020
Re: What is this?
yes. It is a exhaust gas recirculation (EGR) valve. It controls exhaust gases going to your intake. This valve is not required for your car to operate. The entire system is there to help burn hydrocarbons present in your exhaust gases. You may experience lower gas mileage. But yes, you can drive around with it unplugged. Your check engine light will come on. They are not that expensive. By the way if you do try to remove it from the car you may have trouble with the front bolt that holds it in place. It gets stuck in their really good. Go ahead and unplug it and drive down your neighborhood road for a bit to check it out. Good luck.
Old Mar 7, 2020
DonJulio's Avatar
Re: What is this?
The seller is checking to see if he has the correct harness. If I have to use the non egr harness I will replace the whole housing with the non egr 1. Was just checking if that was even an option.
Old Mar 7, 2020
DonJulio's Avatar
Re: What is this?
gearbox
56
Jan 31, 2018 08:32 PM
hwt101
Mar 19, 2009 04:52 PM
civictunr7
Feb 23, 2009 07:58 PM
HwNpRyDe_CiViC
Nov 10, 2007 03:31 PM
kornsined
Jun 3, 2007 08:00 PM
