Where is my engine leaking oil from?
Old Apr 7, 2020
thesupersoap33's Avatar
thesupersoap33 is an unknown quantity at this point
Ok, so... I replaced the camshaft seals about 20k ago and that fixed a major oil loss problem that I was having. Recently, it started losing oil again at about a quart every 400 to 1000 miles maybe. It's a lot for this car. I did notice some oil on top of the motor by the valve cover gasket. When I checked the bolts on the valve cover, I noticed that I overtightened two of the 8 or 10 and they've broke off into the head, so I'll have to replace those at some point. I feel like its losing oil from somewhere else, though. Every time I'm under the car, the subframe seems to have an excess of oil and dirt and grease stacked on the frame.
What could it be? Where should I check? Usually, the bottom of the oil pan and drain plug are dry. Thanks.
Old Apr 8, 2020
Colin42's Avatar
Re: Where is my engine leaking oil from?
What's the mileage? Could be burning it
Old Apr 8, 2020
416k.
I dont know if its burning it though. One quart a month is sort of a lot.
Old Apr 8, 2020
Colin42's Avatar
416k?
Guaranteed it's burning oil.
Old Apr 8, 2020
BrotatoChip's Avatar
Super Moderator
1 quart every 500-1,000 miles is very possible with bad rings.
Old Apr 8, 2020
Bad rings? How can I know for certain that this is the issue?
Old Apr 9, 2020
Colin42's Avatar
Because it's extremely common for the oil control rings to get gummed up and allow oil to get into the combustion chamber on these engines once they get up in mileage
Old Apr 9, 2020
Super Moderator
If you were leaking that much it would be obvious. I'm assuming the engine hasn't ever been rebuilt, if so there's no doubt in my mind it's the rings.
Old Apr 9, 2020
Wouldn't there be smoke coming out the exhaust? There's no smoke: blue, white or otherwise coming out of the exhaust.
Old Apr 9, 2020
FRSam's Avatar
Click Here
It would at higher rpm. Have someone behind you and go up around 5-6k.
Old Apr 9, 2020
Colin42's Avatar
The cat will absorb most of the smoke
Old Apr 9, 2020
This isnt the problem.
Old Apr 9, 2020
Colin42's Avatar
Well it sure as hell isn't losing that much oil through leaking or it would be incredibly obvious where it was leaking from
Old Apr 9, 2020
FRSam's Avatar
Click Here
Just do a dry and wet compression test. That'll confirm what we already know
Matthew Madden
Feb 12, 2020 02:05 PM
Puccillo
Feb 16, 2018 04:05 PM
Kolt R.
15
Jan 8, 2016 08:29 AM
sik92civic
Feb 18, 2010 07:00 PM
youngjosh12
Apr 29, 2009 03:18 PM
