P0139 - Rear O2 Sensor keeps failing
Old Sep 26, 2019
KevinMCody's Avatar
KevinMCody is an unknown quantity at this point
In the summer of 2017, the Check Engine light came on on my '04 Civic. I hooked up my scanner; it said P0139 - Slow response, Rear O2 sensor (the one AFTER the Catalytic Converter). I replaced it with a Denso sensor from Rock Auto. It lasted for about 2 years, then the same code started firing in July 2019. I replaced it again, this time with a Bosch sensor from Autozone. This sensor lasted 2 months, then the same code came back.
My question is: Am I just buying the wrong sensors? I've heard conflicting stories about wide-band versus narrow-band. Both sensors ran about $60.
Could something else be causing the sensors to fail so quickly? Is it possible a failing Catalytic Converter could foul up the sensor somehow? If so, How could I test that?
Old Sep 26, 2019
Colin42's Avatar
Re: P0139 - Rear O2 Sensor keeps failing
Well the Bosch is definitely the wrong one
Old Sep 26, 2019
KevinMCody's Avatar
If it failed so quickly in isolation, I would tend to concur. However, the fact that the previous replacement failed after just 2 years leaves me a tad suspicious that there may be some deeper problem afoot.
Old Sep 26, 2019
Slumpertcivic's Avatar
Downstream sensor is O2 sensor on all 7th gens, upstream was 02 on most 2001-2003, and then switched to wideband A/F for 04-05.
Lots questions follow.
Is the car “consuming” oil? What type of oil and any additives are you using? High level ethanol in your gas pumps? Any fuel additives?
Is the catalytic converter original or a replacement? Are you putting any “anti-seize” products on the sensor threads?
Old Sep 26, 2019
KevinMCody's Avatar
Lots of answers:
I keep pretty good tabs on the oil level, I'm not burning or otherwise loosing much if any (like maybe a millimeter down on the dipstick between 5,000 mile changes?)
I'm using Valvoline High mileage synthetic blend.
I'm pretty sure all western NY gas pumps use 10% ethanol.
I put a bottle of Fuel Injector cleaner into my gas tank after putting in the second sensor (probably about 1 month into its life). Can that possibly cause damage to an O2 sensor?
The cat converter is original.
I have not used anything on the threads.
Thanks!
Old Sep 26, 2019
http://www.tomco-inc.com/Tech_Tips/tip4.htm
I would just put another Denso in it, if it looks like any those pictures maybe something else is going on.
Old Mar 10, 2020
RC46's Avatar
RC46 is an unknown quantity at this point
I'm about to replace an air/fuel sensor (D17A1), and was planning on using a little anti-seize. Why did you ask about anti-seize on the threads? Should I refrain from such things?
Old Mar 11, 2020
Colin42's Avatar
If you don't know what you're doing you'll put way too much antiseize on the sensor and contaminate it
Curtman
Jan 11, 2019 03:32 PM
Skatefrench
Jul 22, 2018 10:11 AM
MichaelEB
18
Jul 26, 2014 10:33 PM
tide55
Dec 19, 2013 11:37 PM
civic99whistler
Aug 23, 2009 03:46 AM
