2004 Civic, 1.7 Engine. Valve job
Old Sep 12, 2019
tott2692002's Avatar
tott2692002 is an unknown quantity at this point
This is my very first post
I pulled the cylinder head due to overheating to replace the gasket. I noticed that one of the intake valves not seated well. ( could be bent )
I’m looking for details procedure on how to remove the valve. I would appreciate if you send me a link.
One more important question please
Do the camshafts need to be removed to remove an intake or exhaust valve ?
Thanks
Old Sep 12, 2019
Re: 2004 Civic, 1.7 Engine. Valve job
Your valve is open because the camshaft is doing its job of opening them...
If you remove the camshaft, the valve will close...
Also, moving thread to correct section of the forums.
Old Sep 12, 2019
Thanks for the reply
do you have a link to a thread on how to do a valve job that include removing the valves both intake and exhaust ? Thanks
Old Sep 12, 2019
Slumpertcivic's Avatar
I had good success using the listle tool for the valve keepers, definitely one of those right tool for job makes it a lot easier.
I suggest replace the valve seals if your pulling it all apart.
Have the torque sequence for removing and installing, just follow that and everything will just come apart.
Be warned, once out of the head, the rockers will slide right off, keep it level and takes lots photos and notes and maybe use different colored zip ties to keep everything sorted if you decide to disassemble for complete cleaning.
Old Sep 12, 2019
Thank you !!
Old Sep 13, 2019
mac25's Avatar
Dr Krieger of Modification
To remove the valves I suspended the head on some 2x4s, with a towel under the valve I wanted to remove, then placed a deep socket (with a magnet in it) on top of the valve. Then I hit the socket with a mallet to depress the valve. The magnet catches the retainers.
To install them again, I set up the 2x4s and towel, placed the retainers on top of the valve, placed plastic wrap on the retainers, so I'd have something stretchable to hold them in place, and see them. Then used a die ad tap kit, handle, to press the spring down.
Youtube has some videos which helped me.
Old Sep 13, 2019
I also used wood, but next time I will use a styrofoam cooler lid. Kept sliding around too easy on wood.
Old Sep 17, 2019
Thank you so much
Old Sep 21, 2019
mac25's Avatar
Glad it worked 😁
Obamargarine
15
Feb 6, 2017 01:54 AM
91LXdriver
Sep 14, 2016 05:17 PM
fernando97honda
Apr 2, 2011 10:49 PM
Tomj333_EM2
Feb 20, 2009 03:41 AM
nateschisler
Nov 29, 2008 09:21 AM
