Oil leak after transmission replacement
Old Jul 10, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Hello everyone, my car has developed a pretty bad oil leak about a month after I replaced my transmission. The oil is definitely coming from between the engine and the transmission, so something happened to my rear main seal. My question is if it is likely a coincidence that the seal started leaking after I replaced my transmission or if something is wrong with my new/used JDM SLXA transmission that is causing the seal to leak. I have read that a bent or warped transmission shaft or torque converter can stress the end of the crankshaft and cause the seal to fail, so the last thing I want to do is spend a day changing the seal only to have the same thing happen again after another month. So should I just change the seal and hope for the best, or is there something I need to do to verify that the transmission didn't cause the failure? Thanks a lot in advance!
Old Jul 10, 2019
Re: Oil leak after transmission replacement
which is leaking?
both have fluids inside
open them up. My crystal ball is on vacation.
Old Jul 10, 2019
Originally Posted by sdaidoji
which is leaking?
Sorry, I should have specified. It's leaking engine oil.
Feb 19, 2017 01:17 PM
Jan 27, 2016 10:20 PM
Muirsy
Oct 29, 2009 05:09 PM
civicwad
Oct 26, 2009 08:08 PM
dmecivic
Dec 9, 2008 02:45 AM
