oil leak...
oil leak...
just recently changed my oil and while i was under there.. i noticed there was a small oil leak on the lefts side of the engine. looks like it is coming from the oil pan seal or crankcase seal.. wonder if anyone knows if there is a common problem with this on our cars or not and how expensive it is to fix
Re: oil leak...
common problem is the rear main seal leaking. just be sure not to overfill the oil and it might go away. you need to figure out exactly where its coming from tho. clean up the oil and then check it again later.
Re: oil leak...
it was leaking b4 i changed the oil and it wasnt overfilled... stiil waiting on the next time i can bring my car into the school shop so i can take a better look at it and clean the engine
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
