vtec question
Old Sep 4, 2019
blues's Avatar
blues is an unknown quantity at this point
vtec question
I've got a 1.7 honda that came with a vtec engine originally, so I did a swat with a japanese engine still 1.7 but without the vtec and just for the record it was an engine built for a standard transmission but mine is an automatic, anyway
re and re went well, but vtec trouble code error was present so I installed a new vtec that fixed my code error but the vtec doesn't work like it used to. I believe this is a simple fix that a honda tech understands right away. tia
Hope I put this question in suitable area.
Old Sep 4, 2019
mac25's Avatar
Dr Krieger of Modification
Re: vtec question
Your ecu is expecting to control vtec, with no vtec head/solinoid, your ecu will through a code, and keep rpm under 3100.
So did you swap the head? You cant just install a vtec solinoid without the Vtec head.
You could also change the ecu to the one that matches your engine, then recode the key/ignition at honda.
Old Sep 4, 2019
blues's Avatar
Re: vtec question
Well that makes absolute sense, I should have known better. thank you
Old Sep 4, 2019
Slumpertcivic's Avatar
Re: vtec question
I honestly did not know Honda even offered a non vtec manual transmission Civic in Japan..
heydude111100
Oct 2, 2011 05:15 PM
MiamiUgen7
Aug 26, 2005 07:16 PM
lazylx
Engine Swaps
Nov 3, 2004 12:01 AM
yellowjacket
Oct 24, 2004 02:33 AM
trance4mer
Jun 15, 2004 03:01 AM
