replace one or four ignition coil?
Old Jul 24, 2019
MrShorty's Avatar
MrShorty is an unknown quantity at this point
In short, Civic developed a sudden cylinder 1 misfire and I'm fairly confident that the coil on cylinder 1 went out (diagnosis details to follow, if you want). I read on here elsewhere that the coils are not a common failure item. The question is -- should I replace only the one cylinder coil and replace the others if/when they fail, or replace all 4? In some cases, I see that it is cheaper per coil to buy a pack of 4 rather than buy them individually, but, if they are not a common failure item, then the other 3 coils may go a long time without replacement. I know that I can roll the dice as well as anyone else, but just wanted to see what others' experiences would recommend.
Edit to add: It has 160k miles on it, if that makes any difference to anyone's opinion.
Diagnosis details. CEL flashing, so hooked up scanner. Scanner shows P0301 cylinder 1 misfire. Look up cylinder ID, then disconnect and pull the cylinder 1 coil. Reconnect the wire to the coil and hook up a spark tester and start engine. No spark on cylinder 1. To compare, pulled coil for cylinder 4 and hooked up spark tester. Lots of spark on cylinder 4. Switch cylinder 1 and cylinder 4 coils. Now lots of spark on cylinder 1 and no spark on cylinder 4. Diagnosis seems pretty definitive, unless you can share a different reason why the no spark would follow the coil.
Old Jul 25, 2019
Slumpertcivic's Avatar
Re: replace one or four ignition coil?
Can’t predict the future for you, but at least when one of these fail you can still drive the car.
Old Jul 25, 2019
GolNat's Avatar
Prelude Owner
How much are they? Do you drive 100 miles a day or just a few? Do you have AAA? Is the cost of replacing them less then the hassle of having one go out again?
Cheap insurance but like Slumpert said it won't leave you stranded. Not a common failure item.
Old Jul 25, 2019
MrShorty's Avatar
They run $60-$100 each. Bundles of 4 seem to be priced at buy 3 get the 4th free. The additional cost of replacing 4 is not insignificant, but not necessarily prohibitive, either. They are easy to change, so there is really no labor to be saved.
Thanks for the thoughts.
Old Jul 25, 2019
GolNat's Avatar
Prelude Owner
Yeah that is a little pricey. Just replaced mine (40k miles) on my GTI as preventative but 4 OEM ones cost $90. Maybe if they cost more they would be more reliable lol
On my Honda's I would just replace the bad one and not worry about the others.
Old Jul 25, 2019
Colin42's Avatar
Don't buy cheap crappy eBay ones, better off getting junkyard ones
Old Jul 25, 2019
I have a set of d17 ignition coils laying around. Maybe 2 sets. Honda OEM, too
Sarahg9106
General DIY
Jan 15, 2013 09:04 AM
97 Civic coupe
Sep 27, 2010 09:13 PM
fondahonda
Sep 6, 2006 06:18 PM
nismostreets21
May 11, 2006 01:48 PM
Purple2001Civic
Jun 18, 2002 03:23 AM
