Cylinder head
Old Jun 9, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Cylinder head
So I'm on here for over a week now talking about my overheating problems I'm having with my 02 civic,now I took the head off,it looks ok to me but I didn't put anything across the head surface to c if its warped. But the intake manifold dont look good at all to me.its just nasty with oily looks on the head and on manifold itself. Look at the pics and tell me what you guys think.
Not sure whats the deal with this.the outer portion of the head looks fine but around the edge of the piston housing on top looks like oil was reaching up there.
This is the input shaft and the bearing at the end of it is the one that people always saying is bad so bought that specific bearing to replace it,but when i opened the transmission case, thats not the bearing that need to be replace,its this big bearing that you actually looking at right there on top of tge shaft. Its shaking badly so i ordered that and two more that was shaking slightly on the counter shaft ,the shaft that goes mext to this this.
This is the counter shaft, there are two bearings under that big nut that you see there. They are shaking like i mentioned before..i ordered these two from this website (OEM PARTS SOURCE).
Old Jun 9, 2019
Re: Cylinder head
It can look good to the naked eye but still be off. Last time I took a head in to get resurfaced, it needed .004" milled off to make it level
Old Jun 10, 2019
Slumpertcivic's Avatar
Re: Cylinder head
Why does it look like a bottle of stop leak is in the coolant moats around the pistons..
Old Jun 10, 2019
Re: Cylinder head
Ok. I will take my head in for resurfacing Tuesday
Old Jun 10, 2019
Re: Cylinder head
Ok..I will take mine in Tuesday to have it check and recondition..
Old Jun 10, 2019
Colin42's Avatar
Re: Cylinder head
Originally Posted by Tracecross30
That's carbon in the egr passages, common for high mileage oil burning engines scrape it out as best you can
Also when you use the new intake gasket make sure it has the egr holes
Old Jun 12, 2019
Re: Cylinder head
That's not the EGR valve bro,that's the intake manifold.. I just got the head back from the shop and they said it was warp and a valve was bent.
Is it recommended to reuse the head bolts? When I bought the head gasket theres a instruction saying using new bolts are required.
Old Jun 12, 2019
BrotatoChip's Avatar
Super Moderator
Re: Cylinder head
Those are EGR passages in-between the intake ports on the manifold. If the build up blocks the passage you will start seeing misfires.
Old Jun 12, 2019
Colin42's Avatar
Re: Cylinder head
Those are the egr passages in the intake manifold.....
if you have the original oem head bolts and they are not damaged you can reuse them
did you not buy the oem head gasket like we told you to?
Old Jun 12, 2019
Re: Cylinder head
I just cleaned the EGR ports on the intake manifold.. yes I got the head gasket like you said
2civic
Aug 28, 2019 09:59 PM
JJ291
Nov 10, 2017 10:16 PM
ineedanswers
Sep 27, 2014 06:09 PM
Viceman
Feb 23, 2013 03:02 PM
judas009
Oct 1, 2012 09:18 PM
