Input shaft bearing issue?
Old Oct 1, 2012
judas009's Avatar
judas009 is an unknown quantity at this point
hey guys i have a lot of noise in my transmission on my 1997 civic LX. it sounds like a bad bearing and is really noticeable at idle when in neutral. However when i push the clutch in the noise goes away. At first i thought it was the throwout bearing, but upon further research it seems its most likely the input shaft bearing. I figured while i have everything apart i should go ahead and replace my clutch and pressure plate and throwout bearing since i dont think has ever been replaced on it and the car is almost at 190k. so my question is do i have the right parts? im looking at ordering 7 and 4 on this diagram
http://www.hondapartsunlimited.com/f...UTCH%20HOUSING
looks to me like that would be my imput shaft bearing and the oil seal is just for good measure. thanks in advance!
Old Oct 1, 2012
Re: Input shaft bearing issue?
That is a trans issue, not throwout. Input shaft bearing is most common.
Looks right to me. Bearing and seal.
Old Oct 1, 2012
judas009's Avatar
awesome thanks, would it be possible that the input shaft bearing is number 13 on this diagram?
http://www.hondapartsunlimited.com/f...MT%20MAINSHAFT
im not sure which end of the shaft its at and just wanted to make sure before i go ordering stuff.
Old Oct 1, 2012
The front input shaft bearing is the one in the first post. This would be the rear. You PROBABLY want the other one. You should be able to tell which one is noisy once it is apart and you can spin each one by hand. If there is any doubt, change both.
Old Oct 1, 2012
judas009's Avatar
cool thanks. i might just order both and send whichever one back that i dont need. ill only have 4 days in which my car can be apart so that doesnt leave much time lol
GolNat
Suspension DIY
May 12, 2022 06:49 AM
chuffsy
May 15, 2015 12:50 PM
Jigee
May 9, 2015 11:18 AM
oqjoi
Transmission
May 6, 2015 06:27 PM
dosmastr
May 5, 2015 12:19 PM
