2002 LX 02 wire connections
Old Sep 24, 2019
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
So i'm rebuilding an 02 lx civic.
I recently put in a JDM engine with an aftermarket header....and no turbo this time...
On my 05 civic, the wiring harness has two 02 sensor connectors located near each other.
This 02 civic seems to only have one 02 sensor connector at that location.
Is there another location for a second 02 sensor or did this year only come with one 02 sensor? if so, is it narrow band or wide?
Old Sep 24, 2019
Re: 2002 LX 02 wire connections
D17A2s had 2 sensors, one by the 90-ish degree bend of the downpipe and one ds of the cat (approximately under the shifter console)
D17A1s had 2 sensors (pre- and post cat) on the exhaust mani/cat assembly, one pre- and one post-cat
01-03 had narrowband
04-05 had wide
Old Sep 24, 2019
BrotatoChip's Avatar
Super Moderator
It should have two sensors still, primary will be a narrow band. On the EX the secondary sensor is connected to what you'd call the engine compartment harness and not the engine harness. The connector is basically right above the sway bar mounted to the firewall. Does your LX have an EX engine harness?
C455 is the secondary sensor connector. C142 is where both connectors would be on a non-vtec harness.
Old Sep 24, 2019
piano55man's Avatar
Thanks guys.
I knew someone would have the info i was looking for.
The car is an LX.
When i get home, i'll check for the 455 sensor.
BTW here are some pics.
I dipped it last week with color changing pearls.
Old Sep 24, 2019
piano55man's Avatar
This is civic #2.
Just fixing it up and going to flip it while i wait for my race engine for civic #1
Old Sep 25, 2019
piano55man's Avatar
Found sensor 455!
Exactly where you guys said it would be in the rear of the engine bay.
Thanks again guys!!!
Old Sep 25, 2019
pfft.. Told 'ya....
I'm digging that pearl. Does it look that good in person?
Old Sep 25, 2019
piano55man's Avatar
pfft.. Told 'ya....
Yes it does!
Of course it does show all the imperfections of the body work
It'll be for sale by end of OCT at the latest
Old Sep 26, 2019
piano55man's Avatar
next question....
Both ends (from the engine harness and the chassis harness) have the same male ends.
Is this correct?
I know on my 05 one is male and the other female....
Old Sep 27, 2019
Super Moderator
Yes, both harnesses use male connectors.
I still don't understand why your LX has that setup. As far as I know that connection in the chassis harness should only be there for the D17A2 engine in the EX.
Old Sep 27, 2019
piano55man's Avatar
I guess i got the lx and the ex mixed up....
uuuuuuuuselessssssss.....
I'm used to tearing everything apart and building my own crap! LOL
Old Sep 27, 2019
tsk tsk tsk.... I thought you were better than that....
Old Sep 27, 2019
piano55man's Avatar
What's that???
You wanna race d17's?????
lol
Old Sep 27, 2019
Super Moderator
I went back and looked at the pictures you posted. I see a sunroof, that's an EX feature. I will now be able to sleep tonight knowing the mystery is solved
Old Sep 27, 2019
What's that???
lol
I mean... I don't have a D17 anymore, but your beast *** build would likely kick my 2018's ***. I love my 2018, but she got a fat *** and carries that extra weight. Nothing wrong with some junk in the trunk tho
For real though, my 2018 weighs about 800lbs more than my 2002 did. Also has about 100whp more than my 2002, so there's that
Old Sep 27, 2019
Colin42's Avatar
just to further confuse things my gold 05 had an d17a1 but it had a sunroof, and almost every other option
Old Sep 27, 2019
piano55man's Avatar
oh crap! Another mystery to solve!!!!
This is getting to be worse than the mysterious loss of coolant in a d17....
Old Oct 4, 2019
piano55man's Avatar
Now riddle me this...
Not showing any power from any of the 4 wires for the downstream sensor connection.
Under dash fuse #4 is good. This is receiving +/- 12 volts.
Is there another possible connection between the #4 fuse and the sensor connection that could be loose/broken?
Old Oct 4, 2019
Super Moderator
Looks like it goes through connector C451 and then up to the PCM connector E.
Old Oct 4, 2019
piano55man's Avatar
Thanks for the diagram!
I saw this last night as well, just didn't know if there was another possible connection.
Old Oct 4, 2019
piano55man's Avatar
I'm thinking of pulling/swapping the ECU because the ignition key is not a factory stock key.
Tells me that quite possibly the key was reprogrammed for this ecu.
I mean, following the rabbit trail of no power to the downstream 02 sensor but #4 under dash fuse is good and getting power...maybe the ecu has issues...
Old Oct 4, 2019
piano55man's Avatar
I just found this in the manual as well.
This may be my last chance effort to check the connection....
File Type: pdf
Old Oct 4, 2019
piano55man's Avatar
Old Oct 4, 2019
Super Moderator
Oof. I found that too but I thought it said that was for right hand drive vehicles so I ignored it. So yes it does look like it could go through there.
Old Oct 8, 2019
piano55man's Avatar
Don't know exactly what i hit...but it's now getting power!
Car will be up for sale by the end of the month!!!!
dspeedcrazy02
Feb 23, 2011 12:20 AM
dspeedcrazy02
Nov 23, 2010 06:13 PM
jra04em2
Jun 2, 2009 07:35 PM
CivicMexicano
15
Apr 22, 2003 11:15 PM
