2002 Hoda Civic EX 1.7 No V-tec Bogs on acceleration stalls runs rough
Old Aug 21, 2019
SpiderBite's Avatar
SpiderBite is an unknown quantity at this point
Been fighting with this car for months now. Just started losing power in the middle of driving it one day. All of a sudden went back to normal. I pulled tested and cleand the fuel injectors. Pulled the hole air intake cleaned it and the iec. I have replaced: up and down stream 02, Map sensor (does not have MAF) ignition coils, pcv valve and engine coolant sensor. The odd thing when i replaced the last it ran fine till i cut it off and didn't want to restart. It has progressively gotten worse to the point I can't drive it any more. The only codes i have gotten is to rich/ to lean bank 2. I have checked all the hoses and gaskets with the break cleaner trick (yeah i know bad for hoses but im desperate) no surge or stalls. So no leak im guessing. Been over hundreds 0f forum posts and videos (people like to not come back and say how they fixed the problem) and i have gotten no where. Please help i need this car.
Last edited by SpiderBite; Aug 21, 2019 at 12:19 PM. Reason: Forgot some information
Old Aug 21, 2019
BrotatoChip's Avatar
Super Moderator
Re: 2002 Hoda Civic EX 1.7 No V-tec Bogs on acceleration stalls runs rough
Have you checked fuel pressure at the rail? You'll need a fuel pressure tester.
Old Aug 21, 2019
SpiderBite's Avatar
Not yet. I can get a tester as a loan from an auto parts but will be a fee. Ill try and get back to you.
Old Aug 21, 2019
SpiderBite's Avatar
I forgot something. Not sure ots a fuel pressure issues because it gives off the foul smell of unburnt gas. Ill still check it asap.
Old Aug 21, 2019
Super Moderator
Post the fault code in the Pxxxx format as well when you get a chance.
GusBuz
Sep 11, 2016 12:11 PM
piotr
Bolt-on Engine Performance
Jun 24, 2013 08:26 PM
zeejay
Apr 10, 2013 11:12 AM
laack
Mar 14, 2010 12:02 AM
andrew58201
Nov 25, 2009 10:24 AM
