Still getting squealing after drive belt change.
Old Jan 15, 2020
SynysterDan's Avatar
SynysterDan is an unknown quantity at this point
Hi there,
Well today I changed my drive belt as I had squealing for a while. The belt I took off didn't look too bad considering it had been on there 5 years at least as far as I know.
So after doing that I still have squeal. There is only 3 pulleys, The alternator looks smooth and straight and so does the AC but the crankshaft pulley has a bit of a wobble. Is that likely the problem?
Old Jan 15, 2020
BrotatoChip's Avatar
Super Moderator
Re: Still getting squealing after drive belt change.
Are you sure the belt was put on tight enough? For the alternator/compressor belt it should deflect 5.6-6.5 mm when a 22 lb force is applied between the alternator and crankshaft pulley. Kind of difficult to accurately gauge that but most try tightening it up some and see if the squealing stops.
Old Jan 15, 2020
Ok thanks. That could be the problem then. I would guess that it is over 10mm but I will have to check again. This was the first one I've done so I was worried about over tightening it.
Old Jan 15, 2020
Super Moderator
Once you tighten the belt with the wingnut make sure you tighten both bolts under the alternator. One from the alternator to the bracket and the other from the bracket to the block.
Old Jan 16, 2020
Cheers mate, I tightened it up this morning and it hasn't squealed since.
Old Jan 16, 2020
Super Moderator
Glad to hear
Baladce
Jul 20, 2020 05:09 AM
firecatf7333
Apr 28, 2018 08:18 PM
robinc88
Mar 7, 2017 01:26 PM
stakwutang
18
Jun 12, 2004 12:44 AM
2001civ
Nov 30, 2002 11:26 AM
