125lb compression reading across all 4 cylinders
Old Mar 1, 2020
Bulzi73's Avatar
Bulzi73 is an unknown quantity at this point
can anyone help I'm getting 125lbs across all 4 cylinders , my question is what should the reading be at ? also could my problem be a blown head gasket. thank you
Old Mar 1, 2020
Colin42's Avatar
Re: 125lb compression reading across all 4 cylinders
What problem are you having that made you do a compression test? Depending on how you did the test your reading of 125 may be "correct" especially since you got the same number for all 4 cylinders
Old Mar 1, 2020
FRSam's Avatar
Click Here
125 is plenty to run if that’s what you’re asking. Mine has 120 on all four cylinders and it runs fine.
Is it running? You’re obviously leaking/burning something from somewhere. 7th gens are notorious for head gasket failure so that’s an option. Are you burning oil? Your compression will be down from that as well. Rings are pretty common as well (that’s the "issue" with mine)
Old Mar 1, 2020
Wankenstein's Avatar
As long as the compression in all cylinders is within 10% of each other compression is good. A breached head gasket betwee two adjacent cylinders would cause those two cylinders to have decreased /low compression. Highly unlikely there would be breaching that would cause low compression on all four cylinders.
jaylo600
Apr 12, 2016 12:22 PM
Northern Civic
Mar 26, 2011 03:37 PM
stayc79
Buy, Sell, & Trade - Archive
Jan 17, 2010 07:38 PM
malibunos80
Nov 16, 2009 04:52 PM
asadrana83
Engine Swaps
Sep 2, 2006 11:04 PM
