2005 Honda Civic EX - Code P2646
Old Dec 19, 2019
devinkkperry's Avatar
devinkkperry is an unknown quantity at this point
I noticed a slow oil leak a few months ago that I’ve been meaning to get around to but I haven’t had the chance. I’ve been checking the oil level and adding accordingly to buy me time until I could fix the oil leak.
But then a few days ago when I stopped at a stop sign I heard the engine rattle, struggle to stay on, and finally shut off. I did notice the Oil Pressure and Battery indicator lights illuminate just before the engine shut off.
Luckily I was only a few blocks away from home so I was able to start it up (by turning the key while giving it gas) and get it home. When I got it home, I checked the oil level and realized I had slipped up and forgot to add oil for a bit too long, because it was very very low.
I used my OBD II scanner and got a P2646: “A Rocker Arm Actuator Control System Performance / Stuck Off (Bank 1)”. I’ve been reading around and apparently people have seen this code resolved by changing the oil filter, so I tried that. I’ve also read that the P2646 code corresponds to “VTEC Oil Pressure Switch Circuit Low Voltage” but I was hoping to get some input here first. Anyone have any ideas? Thanks!
Old Dec 19, 2019
GolNat's Avatar
Prelude Owner
Re: 2005 Honda Civic EX - Code P2646
Depending how low the oil was that may have thrown the code. Have you added oil and cleared the code to see if it appears again?
Old Dec 19, 2019
Slumpertcivic's Avatar
If you car is not leaving huge puddles of oil on the ground and your going through quarts of oil.. Your probably going to have a catalytic converter failure next.
Old Dec 20, 2019
Update:
I thought changing the oil filter didn’t resolve the issue since the engine died out right after starting it, but I guess the oil just needed to circulate because after trying it again and driving it around the block it starts up fine every time now and doesn’t shake like it’s struggling to stay on anymore.
I also erased the codes and it hasn’t come back on yet.
mlandmann
Apr 25, 2013 03:11 AM
Philip54
May 12, 2012 10:13 PM
kames
Feb 13, 2011 03:41 PM
GY58
May 30, 2010 07:54 AM
mrb420
19
Oct 31, 2006 08:46 PM
