View Full Version : Electrical
- Looking for a quality reman or other alternator
- Power Feed Mystery
- 2005 Civic LX SDN. It battery doesn't charge when it's first started.
- Dashboard dials all zero but car is running
- Electrical inside the car don't work!
- Need quick help
- No speedo/tach, no gauges, no turn signals, no headlights
- 30 amp mini fuse spare? Why?
- (Honda Civic 2005 EX) Battery charging issue
- 2001 lx manual. No power at all.
- Tail Light not working
- discontinued bulb for cruise sunroof switch
- DRL not working but Highbeams are
- Fuel pump yellow/green wire not getting Voltage [solved]
- I'm Having an Issue With My Fans!!
- [2005 Civic LX] Fuse 17 (passenger headlight) keeps blowing
- Green connector!?!/driver side
- Case: alternator falls and fries ECU
- Won’t idle after charging battery
- 2001 civic lx brake light doesn't turn off [solved]
- 2001 civic lx will not crank but push starts and starts jumping starter [solved]
- Headlights blinker and what is that
- Passenger door locks but driver side doesn't
- 04 Civic DX AC Compressor/EVAP canister wiring
- door locks will not respond to remote key fob
- 2005 Civic DX - Alternator adjust bolt fail now limp mode
- Front interior defroster problem
- Evap wiring harness
- Help with Odd Electrical Issue [solved]
- Battery dead overnight, voltage dropping and squealing alternator
- Low beasm not working
- Stock headlight wiring for low/high beams. How many Volts when car running?
- Passenger headlight only appears under certain circumstances
- Door lock issue
- No Power to fuel pump
- Help With Turn Signal/Hazards Not Working
- Electrical Issues
- Stop lights not working [solved]
- HELP TAILIGHTS stoped working but brake lights do.WTF
- Passenger side High Beam working but not Driver side+no DRL
- Battery drain
- Electrical issue…I’m stumped lol
- Not sure what that harness is for
- Civic EP3 - Charging Light Stuck On [solved]
- Keeps blowing the voltage regulator
- Dreaded License Plate Light Problem
- Electrical issue, Parking/marker lights, come on with ignition 2002 [solved] EX coupe
- headlights and “brights” light flicker when headlights are on [solved]
- Left rear deck speaker wiring issue.
- Alternator / AC Belt Frayed [solved]
- Infamous radio illumination
- 05 Si hatchback misfires
- ELD and ECT sensors: OEM or aftermarket
- Accessory power with ignition off
- Re: CEL flashes 15 times battery light goes out then limp mode
- 2003 Hybrid Cruise Control
- What is this? A Ground?
- Repin MT cluster to turn on reverse lights on AT car
- Cruise control not working [solved]
- Honda Civic LX 2005 Radio and CD 3 of 4 speakers don't work
- dome light causing noise?
- Buzzing when turning the ignition key
- Battery light flickering
- Turn Signal Flashing?
- low beam doesn't work, but high beam does
- Both low beam bulbs blown simultaneously
- not the usual speed sensor question connector damage [solved]
- Oil light on!
- Is it Intoxalock or something else?? [solved]
- Buzzing Heard From Radio
- 2003 ex civic alternator issue [solved]
- heater blower problem [solved]
- 01 Civic ex manual coupe interior map light,key chime won't work nor head lightschime
- 2004 VP Reverse Lights Do Not Come On [solved]
- Left High Beam intermittent issues - 05 Si coupe
- Weird intermittent crank no start
- identify connector in engine harness 05 civic 1.7 [solved]
- Block Oil Pressure Sensor Cable
- Trunk lid TAIL and licence plate lights out
- Lost ecu ground to O2 sensor heater
- Alternator not charging battery? [solved]
- Passenger window not working and came off regulator
- Race Team Needs Help!
- Mysterious parasitic current
- Headlights - Both sides out. No Low, No High. Switch on steering wheel works
- Electrical issue ( car wont start ) Civic EP2 europe
- Interior electrical issues (door locks, interior lights, etc) - [solved - multiplex]
- 2001 Civic EX battery fuse [solved]
- Fuel pump ground location??
- 2001 Honda Civic Coupe Honda dealer can't get radio to work
- 03 civic center console bulb not working
- windshield wiper goes on when headlights on
- Question related to changing gear shifter bulb [solved]
- Cruise Control Not Working and Airbag Light on
- battery (for honda civic 02) post is switched, 51 v.s. 51R
- Car honks at me if I open a door and remove the key from the ignition
- Big oops
- Intermittent brake warning light flicker/intermittent starting issues
- Hotwiring problem
- Re: Alternator not charging
- Power windows not working intermittently
- Stereo unlock code contains digits not available on the dang radio! [solved]
- 2002 Civic misfiring all 4 cyl, relay clicks intermittently behind glove box
- Not charging battery - 2002 civic
- Driver side low beam no power 2001 Civic EX
- All power door locks not functional. Fuses OK
- (Solved) - brake lights out, shift interlock solenoid clicking when brake applied
- Charging Issues
- 2001 Honda Civic ex
- Battery Light Flickering?
- Car Makes Clicking Sound When Stepping On Brake Pedal
- Interior trim piece question
- Door lock switch and key fobs not working
- Strange codes, P0325, P0219, 23-01
- My civic won’t turn on
- Cluster swap made my Radio stop working
- 2002 Civic Si ac compressor sparking when turned on
- 2005 Honda Civic SE DRL passenger High beam
- 02 speedometer quit
- Alternator Charging Issue
- wiring harness
- Unknown electrical plug HELP
- Battery light and weird thing that fell out from car [solved]
- 2005 Honda Civic EX Coupe Wiring Harness
- Strange Headlight Problem
- Loss of power when attempting to crank (2005 Civic LX) [solved]
- Keyless entry question
- headlight level problem
- PGM-FI relays/crank no start
- 2002 Honda Cuvic 1.7 / auto will not start
- Where?
- ABS Fuse
- Brake lights/reverse lights not working
- 2004 acura el ~50k miles Dead instruments.. help?
- Whoops, Might have blown my window motor
- 2002 civic flickering dashboard backlights.
- No tail lights or brake lights?
- Vehicle intermidiate no crank, battery light after it starts
- Fog Light switch & features?
- 2001 Civic battery light issue?
- Inconsistent Spark on All Cylinders after Engine Reassembly [solved]
- 02 LX electrical issues
- 2005 Civic - Battery Drain
- 2003 civic lx - key wont turn in ignition [solved]
- Smoking battery??
- Brake lights, turn signals and hazard flashers doesn't work
- Window only go one way
- Honda Civic 1.4LS (2001)
- Civic Sedan internal lights
- Interior door lock not working.
- Assuming Underdash Fusebox Electrical issue
- Master door lock switch doesn't lock doors when keys are in ignition
- A/C Pressure Switch Connecter/Pigtail
- High beams/headlights
- Radio: Wire on Harness Shorted
- Both low beams simultaneously went out
- Cruise Control Backlight Not Working
- 2002 Honda Civic LX alternator loses power
- AC compressor switches on and off when asking for power
- CIVIC 2002 No start, Relay click on key turn - PLEASE ADVISE
- 2002 honda civic ex coupe passenger window won’t go down
- Low system voltage
- Weird electrical issue with under hood relays
- Rear Power window driving me crazy
- 2001 Honda civic
- Electrical issue with headlight and lock
- No power [SOLVED]
- Frustrating Charging Issue on a 2001 Civic (D17A) [solved]
- Low Beam intermittent issue.
- Turn signal fuse issues.
- 7th gen Trouble shooting Multiplex Control - inspection connector T1 & T3? [solved]
- Cluster bulbs, Shifter bulb, LED a good replacement?
- Radio Sometimes Doesn't Turn On
- Bypass dimmer switch
- '05 Oxygen Sensor... Help w/P0134?
- No power, no start 2005 ex se coupe
- I need help getting my reverse lights to come on
- Howdy! A/C Clutch not engaging [Partially Solved]
- Ignition Lock Question 2003
- All 3 brake lights not working
- Dan
- P1298 ELD Voltage High
- Both rear windows intermittently stop working
- Alternator
- Doors lock and unlock..... Sometimes
- 12v location for new instrument cluster cover
- 2003 Civic is hard to start but runs beautifully
- Instrument issues
- Headlights flicker with RPM change
- Wire Headlights to turn on when doors unlock [solved]
- 2004 civic Ex headlight alert...won’t shut off
- Cold Outside and Inside AC On allways
- Hazards work on left, but not right
- Tail light relay.
- What does it mean I'ma battery needs rejuvenate
- Brake light problem.
- Electrical fire issue 01 lx coupe
- 2003 Civic LX Highbeam issue
- alarm remote 2002 question
- New Member 2004 Civic hybrid regular battery dying
- Upstream O2 sensor wiring
- Trunk Latch Light
- Honda civic 2004 reverse light socket help please
- 2005 LX - unsure if ger light is a
- New Battery voltage
- Need some help with 04 Civic troubleshooting steps!
- 2004 Civic stereo and cigarette lighter not working
- Slow windshield wipers
- Alternator Bracket - looking for
- Door lock cylinder issues 05 civic
- O2 sensor ground?
- Replaced Driver's Rear Window Regulator
- 2002 Civic si hatch
- Bought A New Starter, still doesnt work.
- Radiator cooling fan not working
- door locks dont work
- Strange electrical problems
- Battery Light Stays On
- Another AC system problem
- Remote and Central locking not working
- A/C compressor clutch?
- Radio fuse keeps blowing
- Passenger side headlight wont turn on.
- P0600 HONDA - Serial Communication Link Malfunction
- My condenser fan fuse keeps blowing.
- Help
- Brake light problem on 2005 LX
- 05 civic instrument cluster issues . Check out my video
- 01 Civic Ex limp mode need help!
- Electrical help!!
- Intermittent Battery light
- 2003 Civic coupe Ignition and engine
- Issue with fog lights
- keyless module
- Immobilizer Hell
- PRNDL Problems - 2005 Honda Civic
- 2004 Civic LX DRL problem
- Drivers power window
- O2 Sensor ECU Swap
- Driver side mirror and speaker problem
- Alternator problem [solved]
- 2005 Civic wires hanging?
- 2005 civic Cruise doesn't work
- Car won’t stay started
- Only engine light and oil light turn on in dash and nothing else
- No start warm engine - Civic 2002
- Need Help locating the Tach Test Connector.
- Repair starter motor solenoid kit, ebay
