PRNDL Problems - 2005 Honda Civic
Old Jun 10, 2020
jonahbrown's Avatar
jonahbrown is an unknown quantity at this point
Hi,
When shifting my automatic 2005 Honda Civic into drive, I have to do it very slowly or fiddle with the shifter to get the green D light to come on on the dash. If I choose to drive without doing this and the D is not illuminated the check engine light comes on after a few minutes of driving. The check engine light resets if i turn the car off and on again.
Has anyone else ever had this problem?
Thanks!
Old Jun 10, 2020
Colin42's Avatar
Re: PRNDL Problems - 2005 Honda Civic
Some of the contacts may be worn in the selector switch
Old Jun 10, 2020
Colin42's Avatar
Or maybe the cable needs to be adjusted
Old Jun 11, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Shift lever does not operate smoothly:
1. Transmission range switch defective or out of adjustment
2. Shift cable broken or out of adjustment
3. Joint in shift cable and transmission or body worn
Check the D4 indicator, and check for loose connectors.
Inspect the transmission range switch. If the transmission range switch is faulty, replace it. If
the transmission range switch is out of adjustment, adjust it and the shift cable.
Check for a loose shift cable at the shift lever and the transmission control shaft.
AZOverlord
Mar 23, 2020 08:07 PM
ZstarZ
Nov 2, 2014 09:10 PM
newhondadriver
Canada West
Oct 8, 2009 05:41 PM
newhondadriver
Oct 8, 2009 03:53 PM
