2002 honda civic ex coupe passenger window won’t go down
Old Jun 20, 2021
Halfironman's Avatar
Halfironman is an unknown quantity at this point
We changed the regulator, and saw the motor was blown, the window went up when we installed it but it won’t go down, we checked the passenger switch and saw that the switch was fine. I am suspecting it’s a shorted wire or something but wanted to see what others think.
Old Jun 20, 2021
Re: 2002 honda civic ex coupe passenger window won’t go down
wiring around the door hinge.
what do you do to enter the car?
open and close it.
wires will be moved every time.
check that part first. very common issue
Old Jun 20, 2021
update: The window does not react when i use the driver side switch, when i pull the passenger side switch up you can hear the motor engage. I’ve read it’s possible that a faulty driver master switch can cause this but i find it odd that the only problem is going down.
Old Jun 20, 2021
check door hinge wiring
check wiring
check wiring
Crazylegs
Oct 17, 2016 09:29 AM
bamahat
Oct 22, 2015 12:11 AM
contevo
Sep 25, 2014 08:56 PM
blonby
Exterior
Jan 13, 2014 06:20 PM
Weekendmechanic
Nov 5, 2013 11:16 AM
