Power window troubles
Old Oct 5, 2012
Weekendmechanic's Avatar
Weekendmechanic is an unknown quantity at this point
The right (passenger) power window in 2002 civic went down and won't come up. I checked fuses, motor/regulator, switch and master switch. Nothing has worked. I can feel the motor engage when pressing the down button, but not when i try and raise it. Pulled the window out so it's not because the windows binding.
Any suggestions would be welcome
Old Oct 6, 2012
Re: Power window troubles
more than likely a bad master switch. had it happen quite a few times and when opened up, the passenger side has burnt residue. you can clean it up with alcohol and reassemble as a temp fix, but eventually it will happen again. i finally just got a new switch and so far its been fine for few yrs. is your passenger side single window switch working? if not then its prolly a bad window regulator/motor.
Old Oct 6, 2012
raymondxcho's Avatar
raymondxcho is an unknown quantity at this point
I don't mean to thread jack but my passenger side window goes up and down a lot slower than my driver side. I'm not very good with electronics so I don't know where exactly to look for the problem. I took off the door panel and cleaned the track or w/e you call it that the window slides on. Greased it, it didn't help much. And for some reason, it is slower when it's coming up. And a lot slower when it's cold.
Do you guys know what the issue might be?
Old Oct 6, 2012
Thanks for the reply. I switched out the motor and regulator, same problem. Then I switched out the single passenger switch, that didn't do it either, so I replaced the master switch on the drivers side. Still didn't work. I'm running out of ideas.
Old Oct 6, 2012
Hi Raymond, did you take the window out and clean and lube the track all the way down into the door? Could just be debris deep in the channel. Did you use dry lubricant like graphite spray?
Old Oct 6, 2012
Yeah I took off the door panel, and I actually used garage door lubricant since that was the only seemingly suitable lubricant that I had. I also cleaned it with alcohol before that. There really wasn't any debris or that much dirt to begin with though.
Old Nov 5, 2013
ezydenco's Avatar
ezydenco is an unknown quantity at this point
I have a 2002 Civic LX. The rear passenger window will go down but not up. I tested the regulator on the other door and it works. I replaced the master switch. Any ideas would be appreciated about where else to look. Thanks.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Jeffdp
Jun 18, 2015 06:18 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
