2002 Honda Accord and Civic
Old Jan 13, 2014
blonby's Avatar
blonby is an unknown quantity at this point
Arrow 2002 Honda Accord and Civic
I have a 2002 honda accord 4 door ex and the drivers side window was giving me a hard time between going up/down I eventualy just stopped using it untill I could fix it. However the other day my 4 year old hit the button and you guessed it I could not get it back up.
I looked on line and fiqured out how to get window back up. I took everything appart and got the whole assemply out. My question is?? Is it possible that it could have been the switch which I did not check before I went through the hassle of taking the mechanism out??
2002 honda civic 4 door the passenger side window does not roll up/down with either switch and no noise either.
How do I fix these ? Where can i order parts? I looked on e bay and found the motor along with the window mechanism looks like its all one piece.
Old Jan 13, 2014
Re: 2002 Honda Accord and Civic
The window track rubber seals (run channel seals) get loaded with dirt and grime, causes the windows to get slow and drag. Spray silicone lubricant helps those a lot. Use it whenever the windows get slow to roll up.
Diagnosis is up to you.
You MIGHT be able to swap the 3 passengers window switches around to check those,
but you will probably have to diagnose if the master switch is working right.
Wiring diagram and voltmeter.
Quite often, a bad window switch just feels a little bit odd or wrong when you use it.
Switches, any dealer can get them.
Look up College Hills Honda parts for discount mail order factory parts on your side of the country.
HTH
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
jessicakaybby
Apr 20, 2015 12:11 PM
smmahan
Apr 15, 2015 08:17 PM
vino
Nov 3, 2001 11:08 PM
