My condenser fan fuse keeps blowing.
I’m a guy. My car’s name is Emma.
My condenser fan fuse keeps blowing as soon as I turn the car on with the AC on. There’s no cold air and the clutch on the compressor is not engaging. I’m hoping that means a bad condenser fan motor is all? And not that I need a new compressor...
Re: My condenser fan fuse keeps blowing.
First thing to do would be to check the voltage at the ac compressor connector. With a new fuse, it should read 12v. If not, it's most likely a bad compressor.
If you're referring to fuse number 1 (20A) in the under-hood fuse box then yes it does run the fan and compressor.
You can try unplugging the compressor then replacing the fuse. If the fuse doesn't blow with the compressor unplugged you can start troubleshooting it. If it does still blow unplug the fan and try again.
g4384063
May 30, 2015 11:21 AM
lecorybusier
Sep 8, 2007 04:19 PM
spikele
Feb 2, 2006 03:32 AM
