I'm Having an Issue With My Fans!!
Old Sep 4, 2024
jh279's Avatar
jh279 is an unknown quantity at this point
Okay I'll start this off by saying that I am a new member and I couldn't find any info regarding this issue on youtube or google as far as I can find.So I figured I would check here in the hopes that someone could help me possibly.
I'll get straight to the issue I'm having with my 2005 Honda Civic Si 1.7l coupe. Awhile back my car was overheating and I had my radiator, water pump, thermostat replaced along with new radiator fan switch as well as a new coolant temp sensor. I also had to get a new headgasket.
The issue I'm having now with my car is that the fans both the radiator fan and ac fan both kick on as soon I turn my key to on but don't start the car. I've checked the relays and they don't seem to be the issue and I can't think of anything else that could be causing it.Engine is cold and not running either.
I'll include an attachment so you guys can see for yourself what I'm dealing with. Thanks for any help!!
File Type: mpg
Old Sep 4, 2024
BrotatoChip's Avatar
Super Moderator
Re: I'm Having an Issue With My Fans!!
Is the A/C or defrost turned on?
Old Sep 4, 2024
jh279's Avatar
Nope.
Old Sep 5, 2024
Super Moderator
The fans can be turned on two ways; the PCM/ECU or the radiator fan switch. The PCM/ECU will only turn them on at a certain temperature. You can verify the coolant temperature it's reading with a scanner that shows live data. The radiator fan switch is located next to the thermostat. When the coolant temperature reaches ~199°F, the switch closes and turns on the fans. I would guess this circuit or switch is bad.
For starters, unplug this switch, do the fans shut off?
Old Sep 5, 2024
jh279's Avatar
Yes as soon as i unplug that switch both fans stop.
Old Sep 5, 2024
Super Moderator
Check continuity across the two pins with a meter. Should be open unless the coolant temperature is ~199°F.
Old Sep 5, 2024
jh279's Avatar
I just put the old rad fan switch in and that seems to fix the issue.
Old Sep 6, 2024
Colin42's Avatar
Was the one you replaced aftermarket?
Old Sep 6, 2024
jh279's Avatar
I had ordered it on rockauto. Maybe I should've got an oem replacement.
Old Sep 6, 2024
Super Moderator
You should see if it came with a warranty.
Old Sep 6, 2024
jh279's Avatar
I don't think it did unfortunately.
Old Sep 6, 2024
Super Moderator
What brand/part number did you purchase?
On Rockauto, under "Electircal-Switch & Relay" then "Radiator Fan Switch" every single one has at least a 90 day warranty. Most are a year or more.
cizsak
Jul 21, 2015 03:39 PM
dkdontforget
Jul 14, 2012 07:46 PM
CV209
Mar 15, 2011 03:28 PM
willy0505
Buy, Sell, & Trade - Archive
May 27, 2009 10:36 AM
Rufus
Engine Swaps
36
May 5, 2009 06:50 PM
