95 civic ex radiator fan?
Old Mar 9, 2011
CV209's Avatar
CV209 is an unknown quantity at this point
Angry 95 civic ex radiator fan?
I own a 95 civic coupe ex with a 1.6 liter SOHC VTEC......
Besides that, My radiator fan stopped working completely, found no issue why it would stop working. Since I bought the car in feb of 09, temp gauge never raised, then all of a sudden it raised to hot and about overheated. I pulled over let it cool down then proceeded to be cautious of the temp til i was able to get it in a safe place. I checked every possible issue that it might have been that caused to fan to go out. I even bought a new radiator.
I now run a wire from the battery to radiator to a switch in my glove box that I have to turn on and off..
Its quite annoying so I could use some help as to how to fix the problem since I am also going to try to sell it soon.
Much help would be appreciated!
Old Mar 9, 2011
J-Master Flex's Avatar
J-Master Flex is an unknown quantity at this point
Re: 95 civic ex radiator fan?
In my experience, the fan never really kicked on unless it needed to cool the engine down. Did you check to see if the fan was running when the car overheated?
My issue is that I am leaking coolant somewhere. Even if you're not having that issue, you'll want to be sure to bleed the coolant lines of any air, and top off the coolant once you're done.
Old Mar 9, 2011
CV209's Avatar
Yeah, I checked while it was rising, it never kicked on once. I've flushed the coolant too before. Hmm. It doesn't overheat anymore since I connected a wire directly and use the switch but, I want to be able to fix the issue so I can sell it.
Old Mar 9, 2011
mkymonkey's Avatar
I haven't been here in a long time
mkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the roughmkymonkey is a jewel in the rough
thermostat?
Old Mar 10, 2011
CV209's Avatar
checked and thermostat is fine.
Old Mar 15, 2011
Then it's gotta be a bad relay switch. That's just about the only thing left.
prowl
Apr 18, 2015 07:50 PM
Hondasport01
Bolt-on Engine Performance
Nov 11, 2001 12:41 PM
Hobby2K
Nov 9, 2001 04:08 PM
