Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
'93 Civic Overheating
Old May 22, 2009
willy0505's Avatar
willy0505 is an unknown quantity at this point
All - I am new to this forum info, but I hope I am now at the right place to get the answer (although i have tried at other forums with no success). The issue:
I recently got into my civic and it had been sitting for about 4 or 5 days and cranked it up and started driving. I looked down after a few miles and my temperature gauge was pegged at high. I immediately pulled over, checked the coolant & it was fine. So then I let it sit all day and night and checked the gauge with just power to the instrument cluster (via a 2 click key turn) and the gauge pegged out at high again. So here are the things that I have done to try and correct the issue:
1 - Replace the Coolant Temperature Sender (the sensor with 1 connector that sits right below the distributor)
2 - Replaced the thermostat (after a drain and then refill of engine coolant)
3 - Replaced the Cooling Fan Relay (in the underhood fuse box)
4 - Replace the Radiator / Cooling Fan switch (thermostat housing)
So now what i find is that i can ride down the road for a bit and the gauge will flucutuate ever so slightly - like when i hit about 45 mph it will creep up but then when i slow down it will drop down a little bit. So today, i cranked it up and let it run and it starts to overheat really slow, but the cooling fan does not come on (however, i know the cooling fan works - because i jumper wired it from the 2 prong plug to the battery).
Any thoughts here.
Thanks in advance for the help.
Old May 26, 2009
McLard's Avatar
McLard is an unknown quantity at this point
Re: '93 Civic Overheating
Fill the radiators with radiator fluid.
Old May 27, 2009
mcgrady01's Avatar
mcgrady01 is an unknown quantity at this point
well i had the same issue with my 92 for a few days. i ended up having i bit of an issue on my hands.
i got my civic with ALOT of miles on it. and eventually ended up with a bad head. she was only running on three cylinders and overheating very very fast.
so i had to do a full head job. get my head resurfaced and new gaskets.
as far as my fan, it quit working as well. so i ended up just hooking it up on a switch. i know its a very "ghetto" technique but with how old my electrical system is i found that to be the easiest fix.
Xuhme
21
Aug 7, 2023 03:40 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
