I need help getting my reverse lights to come on
Old Mar 7, 2021
YumiA2's Avatar
YumiA2 is an unknown quantity at this point
I have a used manual swapped em2 d17a2 that uses a range switch in order to start. Drives just fine while selected in P mode, only thing is my reverse lights don't come on. I know already that it's a white wire or something that you cut and connect to green/white stripe wire coming into the top of the grey plug near the ecu. I also hear there's a need for a second wire that is solid yellow to be cut. I may have already messed up because I have a yellow/black stripe wire and a yellow/red stripe wire . I cut the yellow/black and it was the ecu connecter.... So I'm not sure where to go with this. Anything helps !
Forum Bot
Electronics DIY
May 17, 2004 06:25 PM
Forum Bot
Electronics DIY
May 17, 2004 06:20 PM
mrdan4548
17
Apr 23, 2003 04:19 PM
wh3nw0rdsesc4pe
Mar 23, 2003 09:57 AM
Dizzymofo
Apr 24, 2002 06:10 PM
