DIY: Apexi VAFC Install #1
Old Apr 19, 2003
mrdan4548's Avatar
mrdan4548 is an unknown quantity at this point
I finally got some time go get this done so everyone put aside about 30mins to an hour for this k. I didnt get any pics cause my camera sux, but when you take out the glove box the ecu is directly behind it. Im going to start from the top plug down, there are three plugs that go into the ecu and its best to work with the top down first k. YOU MUST AND I CANNOT STRESS THIS ENOUGH!!! YOU MUST SOLDER EVERYTHING!!!! NO CRIMPING AND NO WIRE TAPS!!!
Things needed:
VAFC
Solder
Soldering gun
Electric tape
2=2amp diodes
Step 1.
Remove the glove box and locate ecu.
Locate the top plug and remove it from the ecu.
Step 2.
Find the green wire that is on the vafc. You want to solder the green wire into the blue wire with gray dots on it. When done use tape and plug the harness back in.
Step 3.a)
Locate the 2nd plug, should be in the middle. Find the purple and pink wires from the vafc, now locate the green with yellow strip on it. You want to cut this wire in half, (Cut far from the ecu to give yourself some room) Now get one diode and shorten the legs a bit where about 1 inch is left on it.
Step 3.b)
Take the diode with the gray end and solder that to the wire that you just cut that is going towards the car away from ecu. (DONT LEAVE THE SOLDER ON DIODE TOO LONG BECAUSE IT WILL MELT THE DIODE) When done tape up the wire and diode.
Step 3.c)
Take the purple wire and solder this to the other end of the diode that has nothing on it. (Be sure again not to leave the soldering gun on it too long) Now tape up the diode and the purple wire.
Step 3.d)
Take the other diode with the gray mark pointing towards the ecu and solder that end to the wire that is coming from the ecu that you just cut. After that take the pink wire and solder that to the other end of the diode. When done tape up the diode and the wires making sure nothing is exposed.
Step 4.
Now locate the blue wire on the vafc, and locate the blue wire with a black strip on it harness of the ecu. Cut this wire in half and solder the vafc blue wire to the ecu. Leave the other end unused. Use tape to tape up the wires. And when done plug the harness back in.
These last steps are gonna be difficult because the wires are kinda hard to get to.
Step 5.
Locate the 3rd plug which is at the very bottom. Find the gray wire from the vafc, now locate the red wire with a black strip on the ecu harness. You want to solder the gray wire onto the red with black stirp. Use tape to tape up the work.
Step 6.
Locate the yellow and white wires on the vafc, now locate the white with a green strip coming from ecu harness. Cut that wire in half leaving yourself some room to work with the wires. Now solder the yellow wire to the end that goes towards the ecu. The white wire goes towards the car. Solder both wires and use tape to cover up work.
Step 7. This one is kinda tricky so BE CAREFUL!
There are going to be two wires on the harness a black with 2 gray dots and a solid black wire. You want to find the black solid wire. After that get the brown and black wires that are coming from the vafc, and solder these two wires onto the black wire coming from the ecu. Make sure that the brown wire is closer to the ecu than the black wire. I put my brown right in front of the black. Solder them onto the black solid wire. DO NOT TWIST THESE TWO TOGETHER!!!! After that use tape and tape up your work.
Step 8.
Locate the red and orange wires from the vafc. Now find the yellow with a black strip and gray dots on it. You want to solder the orange wire closer to the ecu than the red wire. DO NOT TWIST THESE TOGETHER!!! When done soldering cover up with tape.
And finally plug in the last harness to the ecu. Check all connections to make sure that everything is soldered on tightly and neatly. That should cover all the wires and everything that needs to be done. That is the best that i can tell everyone to do. YOU NEED TO SOLDER EVERYTHING YOU CANNNOOOOTT CRIMP OR TAP. Because if you do a good signal will not go through. Hope this makes you people happy and that it works on everyones car. I myself did not do this work but instead my friend whom owns a shop named NBKHUSTOMZ in arlington texas did all the work his name is Tony. And Redline performance dynotuned my car for me.
On another note i got my car dynotuned and it added 7hp. All i had was just an injen cai, It went from 112 to 119.
Old Apr 19, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
hey thanks! this is giving me a headache haha.
Old Apr 19, 2003
mrdan4548's Avatar
So when someone has this done please leave a post and tell me how everything went. So far we have this done on my car, BIGLIMPDAWG's car and hwoody77's car. And no engine light yet so just let me know when someone else has done it k.
Old Apr 19, 2003
R3DL1N3's Avatar
yet another DIY that id rather pay someone to do
Old Apr 19, 2003
Vinh's Avatar
hurts my head just reading it
Old Apr 19, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
i hope this will fix it.ive been having trouble with mines.
Old Apr 20, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
Thanks for the help...I have yet to try this, but tomorrow after my family leaves, I will be attempting it. 7whp with just a CAI is a awesome gain!!!! Wish me luck!!!
Old Apr 20, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
I think it sounds more difficult than it really is.
Old Apr 20, 2003
CarbonFly's Avatar
This is really good. I'm gonna sticky this thread. It's a keeper.
Old Apr 20, 2003
Wanger's Avatar
you know my way works too and it's 50% easier.
Old Apr 20, 2003
CarbonFly's Avatar
Your way was in noway detailed to help a newbie user. I didn't even know what you were talking about. You didn't even know which way the Diode was supposed to go.
Make a better quality description with all of the problems worked out and maybe I'll sticky it too.
But for now this post is very helpful, very descriptive, and this guy was the first to get it right. Remember when everyone flamed him for getting all of the problems worked out in his VAFC, but he didn't post how because his shop did it?
Old Apr 20, 2003
Wanger's Avatar
fine i edited the thread. just saying that i delivered right when i got the fix to work just to give back to this community that has helped me out so much in the past.
Old Apr 20, 2003
CarbonFly's Avatar
THanks for updating the other thread. You are now stickified.
But now I'm confused as to weather I should crimp or solder......LOL
Old Apr 20, 2003
Wanger's Avatar
you know if your like haxor at soldering go for it! for me i'm kinda crappy at it cause i got shaky hands from smoking hehe so i would totally melt the diode :P
Old Apr 21, 2003
triryche's Avatar
triryche is an unknown quantity at this point
I supposed that you invert the pink and purple wire. Check it!
I writed to mrdan4548
Old Apr 21, 2003
CIVIC808's Avatar
what do you mean invert the pink and purple wire?i followed instructions on the diagram.
Old Apr 22, 2003
triryche's Avatar
mrdan4548 says in the instructions that the pink wire match with the green/yellow that connects to the ECU and the purple connects to the car VTEC Solenoid Signal directly
The VAFC manual and ME says that the pink wire connects to the green/yellow who connects to the car VTEC Solenoid Signal directly
and the purple connects to the green/yellow that connects to the ECU
I think that he mistake when explained it
Old Apr 23, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
this is now in the DIY section
OptimisticWay
46
Oct 15, 2015 02:16 PM
cukaracha
Aug 27, 2015 02:02 AM
mrwhos
Aug 11, 2015 02:03 AM
EM_WON
Jul 22, 2015 06:49 PM
Theshwartz35
Jul 17, 2015 11:13 PM
