Driver side low beam no power 2001 Civic EX
Old Apr 10, 2022
Kjmcd13's Avatar
Kjmcd13 is an unknown quantity at this point
Question Driver side low beam no power 2001 Civic EX
I have ruled out fuses and relays in the under hood fuse box, all good so I am hoping one of you learned gentleman can help before I start chasing the wiring harness. Everything else seems to work normally. When I pull the fuse for the DS or PS headlight the PS goes out. I am thinking that this might be a switch problem or perhaps a junction with the under steering wheel fuse box. Hoping you can point me in the right direction because this is vexing me quite substantially.
Old Apr 11, 2022
BrotatoChip's Avatar
Super Moderator
Re: Driver side low beam no power 2001 Civic EX
Was anything modified recently?
Both headlights have separate fuses and relays in the under-hood fuse box. Do the high beams work?
Old Apr 11, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Maybe a short/break in the wires at the harness area?
Low Beam left side out - Honda Civic Forum (civicforums.com)
Old Apr 11, 2022
Kjmcd13's Avatar
Fuses all good as are relays. Just checked and with low beams on I am getting no power at the fuse for the DS lowbeam but w/ highbeams 12V. Why no power at the fuse with low beam? Pass side lowbeam is fine and everything works normally…….High beams work normally…….totally stock…
Old Apr 11, 2022
Colin42's Avatar
There's your short. Check those wires and any connectors they pass through.
Old Apr 11, 2022
Kjmcd13's Avatar
you mean the actual fusebox is shorting/open?
Old Apr 11, 2022
Colin42's Avatar
Most likely the wires
Old Apr 12, 2022
Super Moderator
You're going to have to start electrically troubleshooting to figure this out unless you can find some physical damage. Power at the fuse should remain constant with low/high beams. It is only controlled by the relay which turns on when the switch is appropriately set. Where did you have your negative probe when you measured that?
Sean McConnell
Electrical
Sep 9, 2020 10:12 PM
subless
Lighting
Sep 25, 2017 12:12 AM
caper74
Oct 18, 2008 08:43 AM
Mudd
15
May 18, 2007 08:27 PM
Talino
Sep 14, 2003 06:08 PM
