Help With Turn Signal/Hazards Not Working
Old Sep 26, 2023
CSurge's Avatar
CSurge is an unknown quantity at this point
Post Help With Turn Signal/Hazards Not Working
Currently the Switch works to turn on the high beams and headlights. After replacing the relay and the signal switch the issue persists. I did change the radio unit but after changing the Turn Signals and Hazards would work but now they are not. One indicator would flash quickly on the inside so I know at least one bulb is bad but would two or more bad bulbs cause all of them to not work? Also there is a short to the passenger window wiring but when I had someone look at a diagram they did not seem to be connected to effect the turn signals and the motor for the window isn't even connected due to that just to be safe. The car in question is a 2002 Honda Civic EX. Any help or clarifying questions are appreciated. Thank you in advance. Additionally, the indicator inside the car does not work either
yagelbagel
Dec 31, 2014 07:16 AM
-Yuki-
Feb 13, 2012 10:30 PM
vi3tx13oy
Sep 19, 2011 05:22 PM
dragazn
Aug 19, 2008 06:26 PM
wontonamo
Lighting
Apr 2, 2007 10:52 AM
