help!
Old Feb 9, 2012
-Yuki-'s Avatar
-Yuki- is an unknown quantity at this point
help!
hi.
can someone help me about my honda civic 01
my turn signal is not working, i already try changing my Relay and also my control signal, but still wont work.
help pls ty.
Old Feb 9, 2012
rjones7755's Avatar
Re: help!
If you or the dealership/mechanic recently did any work on the center console such as replacing the head unit, replacing hvac controls etc, you/they may have left the hazard switch unplugged. The turn signals rely on that switch to operate. If you havent touched that since youve been having problems check your turn signal/hazard fuse. Also did you replace the flasher relay?
Old Feb 9, 2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: help!
What about just having a bad bulb-or is it both signals?
Old Feb 9, 2012
-Yuki-'s Avatar
Re: help!
Both signal are not working, alredy change the flasher relay also the turn signal control and still not working, but if i press the hazard everything is working.
Old Feb 9, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: help!
If I am not mistaken the hazards are on a different circuit. Also, there is a recall for the switches for our head lights...get that checked out, call honda and ask them if you qualify for it...
Old Feb 11, 2012
rjones7755's Avatar
Re: help!
In 7th gens the hazard switch needs to be plugged in for the signals to work, i had this same problem after i replaced my head unit and left it unplugged haha. Check the turn signal fuse in the interior fuse box. It's #19 and will be a red 7.5a
Old Feb 12, 2012
-Yuki-'s Avatar
Post Re: help!
check the fuse? thats the 1st thing i did, thanks anyway
Old Feb 12, 2012
-Yuki-'s Avatar
Post Re: help!
i didnt try that yet, but i was thinking because the hazard is working. tnx anyway.
Old Feb 12, 2012
-Yuki-'s Avatar
Post Re: help!
yea the fuse is separate, i already checked that, one thing i was thinking maybe it`s grounded or loose wire, but im not to sure.
tnx anyway.
Old Feb 12, 2012
-Yuki-'s Avatar
Re: help!
bump " more idea please having hard time already.......\
tnx...
Old Feb 12, 2012
itzsleepy's Avatar
itzsleepy is an unknown quantity at this point
Re: help!
tnx...
Only thing I can say is to get a volt meter and test out all the wiring with the hazard on and with the hazard off to see if there is a short anywhere. It's time consuming but the only way to eliminate your the possibilities of where the problem would be at...
Old Feb 13, 2012
mac25's Avatar
Dr Krieger of Modification
Re: help!
so if the hazards work, that means voltage is getting to the bulbs and th bulbs work. which means the hazard switch works. is it possible that the switch for the turn signals (the hand switch next to the steering wheel) has a broken wire or something?
Old Feb 13, 2012
-Yuki-'s Avatar
Smile Re: help!
im not to sure about that, but im gnna check that, but witch wire is for turn signal? is there any diagram or manual that i can download for free
Old Feb 13, 2012
mac25's Avatar
Re: help!
here yu go, don't even have to download http://autoban.com.ru:8080/manual/CivContents.htm
Old Feb 13, 2012
Re: help!
did you look into the recall yet?
Old Feb 13, 2012
-Yuki-'s Avatar
Smile Re: help!
thanks, i will try to check the wire tomorrow, wish me luck
Old Feb 13, 2012
-Yuki-'s Avatar
Post Re: help!
i will try tomorrow,,, thanks....
Old Feb 13, 2012
mac25's Avatar
Re: help!
i think the main section is for the type R (american SI), so makesure to click the section for coupes.
