2004 VP Reverse Lights Do Not Come On [solved]
I checked the fuse 10 under the hood all the under dash fuse and I could not find out what the problem is. Anyone have any ideas why this is happening?
re: 2004 VP Reverse Lights Do Not Come On [solved]
assuming bulbs and fuse are good, next thing I'd look at is the reverse switch/wiring (on the transmission)
BTW, this all of a sudden happened when I switched the dash from the VP dash to the LX dash. I wired it correctly, as all the lights come on when they should. I have an automatic.
OK, so why do some pictures show a gear selector light in the dash gauge assembly, and some don't? The pictures I have seen are for 03-05 LX vehicles, and some have the gear selector indicator light and some dont.
So when I switched the dash back to the original, one of the reverse lights worked. I think the other one is blown. The reverse parking system also came on. So that means that the new dash I put in, because it did not have a transmission gear indicator, did not light up the reverse lights because the new dash was from a manual car.
Sorry I dipped from this thread when I did. Yeah, AT clusters have gear shift indicators, MT does not. I didn't realize the cluster had input into reverse lights turning on. I wonder if you can bypass that.
mbrando1994
Transmission
Dec 27, 2021 04:38 PM
