Cold Outside and Inside AC On allways
Old Nov 24, 2020
Joseph Pastewka's Avatar
Joseph Pastewka is an unknown quantity at this point
I have 2005 Civic and had a dead battery on and off for a week now. Its brand new and when charging it today i removed the +12 vdc and found the relay for the AC was on. I checked the Battery load at over 3 amps, and after removing this relay it was down to almost 0 amps. The relay is somehow getting powered when the ignition is switched off and keys out of the car. How can this be? Is there another relay that is not switching off? I would assume that when you turn off the ignition and remove the keys the AC is off but not in this case? What is the culprit? The ignition switch? The AC switch? It seems the AC relay is doing what it should do if power is applied.
Old Dec 1, 2020
handyandy46's Avatar
handyandy46 is an unknown quantity at this point
Re: Cold Outside and Inside AC On allways
First thing I'd do is just chuck a junkyard relay in it.
mustfirst
Air Conditioning
26
Jun 4, 2020 04:05 PM
Brfitzp
Jun 13, 2015 06:16 PM
roger t
Aug 2, 2014 01:17 PM
samuelito210
17
Dec 17, 2011 10:10 PM
cgrimond
Jun 10, 2011 08:46 AM
