Alternator Bracket - looking for
Old Sep 21, 2020
brokercar's Avatar
brokercar is an unknown quantity at this point
Hey all.
My alternator mounting bracket, the threading for the mounting bolt is stripped.
I'm wondering what the part # is for it? $60???
Or
I'm thinking about shelling out for a helical type thing. $60?+????
Or
Drilling out a 3/4 recess and epoxying in a bolt with the right thread. $20
Where can I buy a bracket? I see them on eBay, not sure if I want that route. but the engine mount bolt threads are sorta stripped too.
It'd be good to have the part # to help in shopping.
I've never used a junk yard before. Prolly;ly a good place to start
Old Sep 21, 2020
BrotatoChip's Avatar
Super Moderator
Re: Alternator Bracket - looking for
I believe you are talking about the top alternator bolt? Part number 11910-PLC-010, about $50 before tax and shipping is what I'm seeing. Should be real cheap if you pick it from a junkyard.
I won't say it's the right thing to do but I bought a Civic once with the threads stripped out. Previous owner drilled out the remaining threads completely, bought a longer bolt that went all the way past the old threads, then put a locking nut on the end.
Old Sep 21, 2020
brokercar's Avatar
The bolt is fine, but yes, its the bracket threading for the bolt thats stripped. Damn aluminum everything on this car.
I looked into getting a longer bolt and adding a nut on their... but even the original bolt just barely fits into the bracket mount as is given the space. You did this? Perhaps the bolt I got was too long?
Old Sep 21, 2020
Super Moderator
I was likely replacing the head gasket on that car so I would have had that engine mount off. I must have jacked up the engine until I could get the longer bolt out.
Old Sep 21, 2020
brokercar's Avatar
Hmm. I could do that now, but, that sounds a little too permanent and inflexible for how often I work on my car...
Old Sep 21, 2020
Colin42's Avatar
Bracket would be like $10 at the junkyard...
trellex
Electrical
Jul 9, 2015 12:01 PM
j.squared
24
Feb 1, 2014 05:57 PM
maver1k
Nov 15, 2013 12:40 PM
brian02
Aug 18, 2010 11:08 PM
DeX
Aug 7, 2007 09:40 PM
