Alternator not charging battery? [solved]
Old Sep 4, 2022
sdx3812's Avatar
sdx3812 is an unknown quantity at this point
The battery on my 01 Civic DX keeps dying. Had the battery tested and its fine. I checked the alternator and it outputs 12.8v when idling. Is there anything else I should check before replacing the alternator?
Old Sep 4, 2022
re: Alternator not charging battery? [solved]
parasitic draws
Old Sep 4, 2022
sdx3812's Avatar
Originally Posted by sdaidoji
parasitic draws
Looks like there's a .06 amp draw from fuse #9 (Backup) under the hood. Is that enough to kill the battery?
Old Sep 4, 2022
Colin42's Avatar
12.8v is too low. If you turn the headlights on does it jump up at all?
Old Sep 4, 2022
sdx3812's Avatar
Nope, voltage goes down to 12.7 if I turn on the headlights.
Old Sep 4, 2022
Colin42's Avatar
Needs an alternator, needs to be oem. Get one from a junkyard if you don't want to pay the price of a new one.
Old Sep 4, 2022
sdx3812's Avatar
Ok, thanks. Will an alternator from any 01-05 model work?
Old Sep 4, 2022
Colin42's Avatar
Correct, Acura el will work as well in the same year period
Old Sep 5, 2022
sedan or coupe.
Hatch is a different engine
Old Sep 19, 2022
sdx3812's Avatar
Replaced the alternator with an OEM. Battery is now charging at 14.3v when idling. Thanks guys.
Old Sep 20, 2022
BrotatoChip's Avatar
Super Moderator
Re: Alternator not charging battery? [solved]
Another win for OEM parts!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
conceptvbs
Electrical
Jan 13, 2020 09:16 PM
billyh25
Electrical
Dec 7, 2019 09:04 AM
MD3K
Electrical
May 19, 2017 12:24 PM
alexcelbun
Nov 24, 2014 07:36 AM
