New alternator, new battery but not charging?
Old Jul 5, 2016
conceptvbs's Avatar
conceptvbs is an unknown quantity at this point
This is for the 7th gen (2001 - 2005) Civic.
Replaced by car battery and alternator. Still only getting around 12.7 volts with headlights and fan on at the battery terminal.
Of course, after a couple of starts, the battery loses it charge and the car needs a jump start.
Could it be the PCM? I've checked the cables on the battery terminals, and everything is okay except the wire ground from the engine block to the radiator support frame has a white halo around the screw point.
Thanks for the help!
Old Jul 6, 2016
mac25's Avatar
Dr Krieger of Modification
Re: New alternator, new battery but not charging?
Take a multimeter and check the ground connection has continuity with the negative terminal, perhaps?
Old Jul 6, 2016
Junk alternator?
Fuse blown for alternator?
Voltage drops in either the hot or ground between alt and battery?
Any decent service manual should have basic troubleshooting information.
Old Jan 13, 2020
engineenigma's Avatar
engineenigma is an unknown quantity at this point
Unless you are using the Haynes total waste of money manual. Useless dribble.
Old Jan 13, 2020
Colin42's Avatar
There is a free link to the factory service manual on here
bigdaddyclint
Electrical
Aug 22, 2023 09:54 AM
mclld
Dec 17, 2013 01:13 PM
GERRYC
Jul 30, 2012 03:43 PM
Strife419
Aug 3, 2011 02:49 AM
axn666
Buy, Sell, & Trade - Archive
Mar 7, 2008 04:01 PM
