alternator not charging battery
I had an issue with my 02 civic 1.7 ex.
lost all power car was only running off battery so I replaced the battery and alternator..new alternator tested 4 times and is good but it doesnt charge the battery..I checked all the fuses. . what else could it be
Re: alternator not charging battery
What do you mean by “Tested”?
They hooked tester up while car was running and it showed it was charging, or you set the alternator on the counter and they plugged it in and said it works?
Never heard of them, Honda's don't like aftermarket alternators.
As long as you've checked that you don't have any blown fuses, that cheap parts store alternator is the problem. There's like 2 or 3 people every month posting here with the exact same problem
Browns149
Sep 11, 2018 10:12 AM
Strife419
Aug 3, 2011 02:49 AM
