Civic EP3 - Charging Light Stuck On [solved]
Hello! So this one is finally one I know a bit about - electrical - so hopefully I can give you guys ample information in this first post.
I have a 2004 Honda Civic Si 2.0L Hatchback with a Charging System Error light(red battery light) thats been on ever since I bought the car. I have replaced the alternator myself with 4 different ones(under warrantee) that were all confirmed charging before and after being put in. Light remained lit throughout all of this. I then read to try unplugging the 4-pin connector from the alternator and turning the key to ON. Light remained lit. I then started the car for maybe 10 seconds. Light remained lit.
Next up, instrument cluster diagnostic mode. In this mode, the battery light did turn on and off with the rest of the lights.
Next im thinking grounding problem maybe? I cleaned the two main grounds coming off of the NEGATIVE battery terminal. Light remained lit.
So this is what I genuinely consider the fun part where I get to check for electrical wiring problems on a vehicle(ive never done this before on a car).
Just a rundown for those who dont have access to the wiring diagrams:
(Keep in mind I may be wrong with some or all of this. Im not a trained professional)
Alternator plug has 4 wires(WHT/GRN, WHT/RED, WHT/BLU, BLK/YEL).
BLK/YEL is switched with the ignition to battery positive.
WHT/GRN goes to the ECU(pin B18) for "ALTERNATOR CONTROL SIGNAL"
WHT/RED goes to the ECU(pin B13) for "ALTERNATOR FR SIGNAL"
WHT/BLU goes to the ECU(pin B10) for "ALTERNATOR L SIGNAL" and signals to the ECU to turn on the battery light by grounding this wire
Continuity/Resistance check with a multimeter shows all wires had continuity from the alternator plug to the ECU connector except for WHT/RED(ECU pin B13) which had no connection at all. I ran a new wire for that and spliced it in. The Light remained lit.
I then unplugged both ends of the wires(ECU & Alternator plug) and tested each one for continuity with ground. None did.
Any ideas before I throw $600 or whatever it is at a new ECU and programming it?
re: Civic EP3 - Charging Light Stuck On [solved]
Correct. From what I understand the one that I got with the car that was throwing the light was the original alternator that came with the car. They could have been lying to me though for all my knowledge on that goes. I've heard here and there that this light will be shown unless you use a OEM alternator. Is there any reasoning behind why that keeps getting said? It's going to be expensive and difficult to find one. At that point I'd just emulate what it wants with a micro controller on the ecu pin side of things. I just want the light to go away honestly lol.
Honda's dont like aftermarket electronics. Find a used oem one or suck it up and pay for a new one.
EDIT:
I guess it was you who said it, so maybe there was some conflicting info back then in 2017 here
Car-part.com for junkyards. I'm sure there's other models besides the ep3 that use the same alternator
As a cherry on top, the parts store is willing to refund me for the original alternator I bought in full no fuss.
Again for SEO, 2004 Honda Civic Si with Denso alternator from Amazon makes charging light go off.
markrstephen
Electrical
18
Jan 21, 2022 10:16 PM
Nephlite2k
Electrical
30
Apr 26, 2021 05:33 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
