2002 SI Battery light always on with new alternator
We replaced the failed alternator of my CIVIC SI with an aftermarket alternator. The new alternator worked fine except that the battery light did not not go off. We tried another alternator (aftermarket,same brand and model) and again we got about 14 volts, but the battery light stays on. What could be the cause of the problem?
Thanks
Thanks
Re: 2002 SI Battery light always on with new alternator
That 4 wire connector on the alternator...unplug it and see if the red battery light goes out.
Access to that connector is not possible without opening up the front of the car again. Before I do it could you please provide additional information on why the connector should be unplugged? It would appear to me that the connector is the only connection between the alternator and the car electric system. So if it is unplugged, the alternator does not charge the battery.
Thanks
the fat wire held on with a 10mm nut is the positive output of the alternator, the 4 pin connector is what the ecu uses to control the alternator output. If the light goes out when you unplug that 4 pin connector then that shows that the alternator is no good.
Thanks. Could you please advise if there is any risk of damaging anything in running the engine with the alternator not controlled by the ECU? I assume that there is not, since you are recommending doing it, but perhaps that is acceptable only for a short time.
Unplugging it is (usually) a simple and quick diagnostic step.
Just follow instruction and post the result (observation).
Eventually I had to take the car to the Honda dealer. The under dash fuse box and the detector unit in the under hood fuse box were replaced. The lights on the dash are off now.
