low beam doesn't work, but high beam does
Old Jan 29, 2023
adrianmcli's Avatar
adrianmcli is an unknown quantity at this point
Car: 2003 LX Sedan
Bulb: H4 Dual Filament (high/low beam)
Problem: Right headlamp not working, but when I put on the high beams it works just fine.
Some people online point to a relay issue, but shouldn't both headlamps have the same issue then?
Upon further research, it's more likely that one of the two filaments in the dual filament bulb has burnt out. In which case, I will need to replace the bulbs.
Do you agree that it's probably a bad bulb?
If I replace the bulbs, should I buy those LED ones on Amazon?
Or find a halogen one that matches what my car came with?
Thanks in advance.
Old Jan 29, 2023
Re: low beam doesn't work, but high beam does
choosing LED bulbs to be used in regular non-projector type housings is tricky.
https://www.civicforums.com/forums/2...ype-bulbs.html
not a DIY how-to article, moving to mechanical issues section
Old Jan 29, 2023
Colin42's Avatar
First step is to always check the bulb
Old Jan 29, 2023
yeah, just remove them to see if the filaments are in one piece or more
ILT_Civic
Electrical
Jul 31, 2021 06:21 PM
allenmatt8811
Lighting
Apr 2, 2013 01:24 AM
EM2 Bluez
Feb 3, 2006 12:21 AM
Blckcivic01
Mar 24, 2003 11:35 AM
chicohonda02
Feb 9, 2003 01:07 AM
