Light Problem....
Old Mar 23, 2003
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
Light Problem....
my headlights dont work anymore high beams or low beams.... about a week ago just the low beams went and i had tor oll around on high beams....all the fuses apear fine.... what about the relays ???could they need replacing if so where do i get them... and which ones to replace???? HELP !!!!
Old Mar 23, 2003
Dr5D's Avatar
dude its prob the bulbs! have you checked those yet????
Old Mar 24, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
yea....... running on high beam all day and night is killer....
Your high beam probably blew out and your low beams too....
So look inside your bulbs.... are the string size wires disconnected....
if so you need new bulbs....
If you dont' know how to check bulbs than.... i dunno what to say...
Old Mar 24, 2003
i have cheked the bulbs they arent it i mean when i turn on my high beams the lil icon on the dash doesnt even come on....
Old Mar 24, 2003
Mbow's Avatar
You may have burnt up the wiring harnesses, which is somewhat common when using aftermarket bulbs. Switch out the bulbs for stock and see what happens and check all fuses, again. If everything checks out, a trip to the dealer is in order. Put the oem bulbs back in before taking it in.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
