HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
Choosing LED bulbs to replace stock halogen type bulbs
Old Jun 7, 2022
there are dozens of LED lights, but on older cars, you need to be very careful - the LED might actually change the light spread in a negative way and might be similar but the light will spread and blind the drivers on the oncoming lane.
There are two things on the older halogen lights that direct the light:
  1. the reflector behind
  2. the lenses pattern - when you can't clearly see the inside on the headlight - the pattern is there to refract the light to the proper direction
The main issue is that the reflector and refractor depend on where the light filament is... They are calculated based on the light source position...
LEDS... Not all of them are same position.
Let's use the original H1 type bulb:
this LED.... most likely to fail. too log, too wide - light will be all over the place.
this one, might be close? would need to test, though
The video below explains in more details
Old Dec 14, 2023
Pnutt559's Avatar
Pnutt559 is an unknown quantity at this point
Re: Choosing LED bulbs to replace stock halogen type bulbs
Thanks for the info, much appreciated
danwat12345
Mar 5, 2015 07:26 PM
carid
Oct 20, 2014 04:48 AM
WJackson2006
Lighting
Aug 21, 2011 07:32 PM
rice4lyfe
Nov 2, 2007 08:22 AM
gearbox
Lighting
Jun 13, 2006 07:27 AM
