Strange codes, P0325, P0219, 23-01
So I drove my 2004 Civic DX for the first time in at least a week (I've been driving my SUV since we've had snow and bad weather) and I didn't get far down the road before the CEL light came on. I pulled codes and had three of them. P0325, P0219, and 23-01. I cleared the codes and P0325 came back pretty quickly. I'm going to check the voltage on my knock sensor to see if that needs to be replaced, but should I be concerned about the other two codes, and could they be related? The 23-01 code seems to be related to the knock sensor, but what about the P0219 engine speed code? Would that be related to the knock sensor being bad? Maybe I have a bad wire or the ECM is going bad? Thanks in advance for any advice!
Re: Strange codes, P0325, P0219, 23-01
Just to update... I decided to go ahead and order a new knock sensor, which I will be installing later this week. Hopefully that eliminates the trouble code. I have to install a new cat manifold anyways, so I figured I'd do both at the same time. Also considering getting new O2 sensors with the new cat.
the pain is that there are lots of stuff to remove before getting to the knock sensor. Not really sure if OEM is needed, but for the work, maybe getting OEM is better. Don't forget to tighten it (don't ask why i say it...)
HCivic2006
Jul 29, 2017 06:06 PM
Nikg
Jan 16, 2015 10:53 AM
CivicBoi1998
Nov 17, 2013 11:47 AM
BurningOutcast
Mar 5, 2013 02:33 AM
