Lost ecu ground to O2 sensor heater
Old Sep 10, 2022
Blessed7th's Avatar
Blessed7th is an unknown quantity at this point
02 civic d17a1 with p0135 code. Sensor 1 heater circuit malfunction. I have my 12v but no ground from ECU. I checked for ground at the ECU connector so it's not a wiring issue and is not a sensor issue (so please don't ask about the sensor). I need to know what the ECU is looking for that determines if it needs to run the o2 heater or not. Is it looking at the ECT sensor? I just need to figure out what commands the ECU to turn the ground on for the heater circuit for O2 sensor 1.
Old Sep 10, 2022
Colin42's Avatar
Re: Lost ecu ground to O2 sensor heater
Still going to say sensor if the harness side is good
Old Sep 10, 2022
Blessed7th's Avatar
Did you not read my post? How is a bad sensor that is brand new and ohms out just fine going to make the computer send a ground to make it work? You don't understand how the system works evidently. It's like telling me to replace the light bulb because the switch isn't turned on. Heater circuit isn't going to work period without a 12v and ground, end of story.
Old Sep 10, 2022
Colin42's Avatar
I did read it......
What brand is it and where was it purchased from?
Old Sep 10, 2022
Originally Posted by Blessed7th
How is a bad sensor that is brand new .
this is the first time you are telling us that the sensor is brand new?
chill down, that info is important to omit.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
rileysowner
Feb 12, 2023 07:52 PM
Yagnats
Electronics
Jun 12, 2022 08:16 PM
W123Mech
Electrical
21
Jan 31, 2021 11:59 AM
scottwillcocks
Jun 1, 2007 03:19 AM
