01 Civic ex manual coupe interior map light,key chime won't work nor head lightschime
Old Nov 23, 2022
J31's Avatar
J31
J31 is an unknown quantity at this point
My interior lights won't come on with doors open, nor my keys warning, neither when I got the keys on switch or when my head lights are on , I'd check all the fuses and all of them look fine, I changed the door jamb switch on both doors and still nothing, but the map lights will turn on if I press them does anyone have any idea of why isn't working the wires on the connector switch on the door jamb apparently looks fine, also did check the fuses under dash board and all of them are fine as well help please , by the way I used to have a xenon led headlights and they went out,so I took off the xenon led light bulbs and replace them with a just regular led light bulbs , now the new Led light bulbs are working just fine but since then the map light and key chime and head lights warning hasn't worked does anyone have any clue about it
Old Nov 24, 2022
Re: 01 Civic ex manual coupe interior map light,key chime won't work nor head lightsc
check wiring at the door hinges
[this is a recorded auto response for FAQ]
Old Nov 24, 2022
J31's Avatar
J31
Is there any video of how to check the wiring at the door hinges? Thanks for texting back
Old Nov 24, 2022
pull the boot around the wiring
Old Nov 24, 2022
J31's Avatar
J31
If there is a wire loose where do I plug it back? Or how do I test the harness or how to know if the harness still works?
Old Nov 24, 2022
if you are not familiar with electrical work and using a multimeter, take to a shop.
Old Nov 24, 2022
J31's Avatar
J31
I am familiar with it but how much ohms I need to get or voltage? Thanks for answering
Old Nov 24, 2022
your opening/closing the door causes stress failures on the wires, i saw insulation cracks and could feel a soft spot in the wires
tried continuity?
raymondxcho
Lighting
Mar 31, 2012 01:45 AM
Spiked Joker
Jun 15, 2010 12:46 PM
ZSKCivic01
Jan 4, 2005 04:50 PM
blazed870
Lighting
Nov 23, 2003 01:03 AM
RedDragon333
Jan 27, 2002 01:27 PM
