Accessory power with ignition off
Old Apr 11, 2023
sdx3812's Avatar
sdx3812 is an unknown quantity at this point
I would like to wire an accessory so it has power without the key being in the ignition. Is anyone aware of the best way to do this? I couldn't find any fuses that have power without the key in ignition.
Old Apr 12, 2023
BrotatoChip's Avatar
Super Moderator
Re: Accessory power with ignition off
Do you have a sunroof? Fuse 7 (20A) seems to be the only one with constant power in the under-dash box. It's the battery feed for the sunroof.
There's a battery feed to the radio, cluster, and under-dash fuse box. Wouldn't be difficult to tap into them. Or run a wire from the battery through the firewall.
Old Apr 12, 2023
123Krash's Avatar
123Krash is an unknown quantity at this point
What do you plan to run ?
Be careful adding additional load to existing circuits... they are fused according to expected load.
Adding an LED light is way different than adding an amplifier,
Old Apr 12, 2023
sdx3812's Avatar
No sunroof unfortunately. I would like to wire up some low power LED lights (with a switch to turn on or off).
Youngrob650
Nov 12, 2015 11:01 PM
blazed870
Jun 27, 2007 09:49 PM
runner1738
Apr 29, 2005 05:00 PM
kjgracing
Feb 21, 2003 11:52 AM
LudlamTheory
Oct 17, 2002 01:13 AM
